hi, i'm trying to disable auto arm because i've avoided installing the immoboliser as the car has an excellent one already. i cannot seem to get the clifford to get into programming mode.
but also i noticed if i hold down the arm/disarm button it don't go into panic either, yet the siren works because if i trigger the boot/bonnet etc the alarm goes off!
can someone take me through either factory resetting the unit as it was second hand or help me disable auto arm because i can't have the proximity sensor switched on - 30 seconds later the alarm goes off because it can see me driving!
