Username: Mr_kebo Albertville,
Al
Post Number: 443 Registered: Nov-04
Thursday, September 07, 2006 - 08:30 GMT I need some help with a box that the max extrnal can be is 23.5x17.5x13.5. I need it tuned to 34 hz. im having trouble making it fit with that port area.
Username: Fandim Reno,
Nevada
United State...
Post Number: 1340 Registered: Jun-05
Thursday, September 07, 2006 - 09:06 GMT You do realize that if that's the max external specs it can be, you're probably much better off making it a sealed box?
Al
Post Number: 444 Registered: Nov-04
Thursday, September 07, 2006 - 09:12 GMT well its for a 12" sx its tuned to 28hz now
Username: Basshead86 Google is your Friend,
FL
Post Number: 5650 Registered: Aug-05
Thursday, September 07, 2006 - 15:03 GMT you are going to have to sacrifice some tuning man.........
FL
Post Number: 5651 Registered: Aug-05
Thursday, September 07, 2006 - 15:04 GMT or use aeros.....
Al
Post Number: 445 Registered: Nov-04
Thursday, September 07, 2006 - 17:55 GMT guess im stuck with 28 lol i had trouble getting that to lol
Username: Adam_s Wisconsin
Post Number: 217 Registered: Aug-04
Thursday, September 07, 2006 - 18:39 GMT how can you have it at 28 right now?? are you using aero ports because to tune it higher would actually require less port length...so im kinda confused...
Username: Crayola0 Wisconsin
Post Number: 960 Registered: Jun-06
Thursday, September 07, 2006 - 21:07 GMT just use subwoofertools.com and try it there unless thats what u already tried
