Headunit question
Username: Nyyfan13
VA USA
Post Number: 139
alrite, my stock headunit is double DIN, the new headunit im getting is a single DIN. Since the single DIN is half the size of double DIN, im gonna have some room underneath my new Headnuit. I know there is a "dash kit" (not sure if thats it name) that i can buy and put it underneath the headunit to cover the gap between the headunit and dash.
where can i buy one of these things at?
thanks
Username: Rick_ross
Post Number: 485
you can buy them at most car audio stores
Username: Alias747
MN
Post Number: 1220
I got a dash install kit for 18 bucks at BB for my car. One for your car should be about the same.
Username: Nyyfan13
VA USA
Post Number: 140
alrite, good deal, thanks
Username: Splmonster
Nowhere, OH USA
Post Number: 407
check sounddomain, they usually have a diff couple models for each vehicle, they even for my car, that im goin to but( since mine is double DIN) instead of having just like a pocket under it, it has a couple cd holders, seems pretty cool, id check them out, and depending on ur car check out HUmount.com i have it for my GP works and looks AMAZING ive got more compliments on my humount than my hu hahahaha
Username: Nyyfan13
VA USA
Post Number: 141
haha alrite ill check them out. thanks
Nowhere, OH USA
Post Number: 410
wow i just re-read that.......... i sound like a stammering idiot, lol i get excited hahahaha
Username: Nyyfan13
VA USA
Post Number: 142
haha its straight.
unfortunatly humount.com didnt have my car. i checked out some other ones just to see what tney looked like and they looked real tight.
thanks anyway tho
Username: Crayola0
Wisconsin
Post Number: 954
i got mine for 10 bucks at walmart and it works great
