Best for money
Username: Bga44
Tampa, FL
Post Number: 244
im looking for sub,amp, and box all under $200. i was considering the infinity basslink models. anything else you all would recommend? BAzooka
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 865
wow your gonna have to save more money if you dont want junk...
Username: Basshead86
Google is your Friend, FL
Post Number: 5591
i would look at the Ascendant Audio Assassins...they are very nice subwoofers with excellent SQ and get fairly loud.
also you may want to check out FI Car Audio X's. they are about the same price and although not many people have experience with them...i am willing to bet they are in the same performance range as the Assassins or perhaps the RE RE's.
Username: Naledge503
Portland, Oregon U.S.
Post Number: 208
B.D. is selling his MTX roadthunder setup for $200
https://www.ecoustics.com/electronics/forum/car-audio/266196.html
Post Number: 5594
lol!!!^^
Post Number: 209
If you had even $50 more you could get something like this.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D290025313069&ru=http%3A%2 F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26satitle%3D29002531 3069%2509%26fvi%3D1
^^^get the 8 ohm version
http://cgi.ebay.com/Audiobahn-A4002T-Intake-Series-2-Channel-Amp-NEW_W0QQitemZ22 0023354858QQihZ012QQcategoryZ48597QQrdZ1QQcmdZViewItem
that adds up to $189.20 save a little more and get a prefab box
http://cgi.ebay.com/DUAL-VENTED-10-PORTED-CAR-AUDIO-WOOFER-ENCLOSURE-BOX_W0QQite mZ270026061654QQihZ017QQcategoryZ14945QQrdZ1QQcmdZViewItem
That adds up to a little less than $250
Username: Adam_s
Wisconsin USA
Post Number: 212
I would go with the a4002t off ebay for around 85 shipped and then either a 10" or 12" assasian which are 70 or 90 depending on size and then you could build your own box and it would be an alright system.
Post Number: 210
^^^agree. $200 is not a fun budget to work with. If you can build a box or have friend build one for you, you could do alot better than what i posted. I was just giving an idea.
Username: Adddisorder
West palm, Florida
Post Number: 765
if you can save a little more get an assassin 12 and a pg x400.1 awesome set up and cheap if you get the amp used or off ebay. youll be very happy with that.
or get 2 assassin 8s with a cheap amp off ebay maybe audiobahn a6004t and bridge it
Username: Delsole
Post Number: 816
that would work well ascedent audio make some good but pretty cheap speakers/subs
Username: Darkale85
Averil park , Ny Renn
Post Number: 195
hey if u want to 12" jl w0s with a jl 250/1 i have that for 200 but u pay for shipping let me know if u want email me at darkale85@yahoo.com
