Bronze Member Username: Tremor1127Post Number: 86 Registered: Aug-06 | there are so many amps out there, what amps can be had with around 3000@1ohm and 1500@2ohm... or anywhere in that area... |
Silver Member Username: DrsmithMontana USA Post Number: 291 Registered: Nov-04 | budget???? |
Bronze Member Username: Tremor1127Post Number: 88 Registered: Aug-06 | not really a budget, but the cheaper the better... good quality though... |
Silver Member Username: DrsmithMontana USA Post Number: 302 Registered: Nov-04 | i just asked showrides about the MA p3000.1 just watch my thread and see what he says |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2137 Registered: Dec-05 | the MA is two ohm stable... i'd say soundstream pca 3500d, autotek mm4k... |
Bronze Member Username: 04redmach1Columbus, GA USA Post Number: 70 Registered: Mar-06 | The Massive Audio is 2 ohm stable only. Why are you needing 3000@ 1 ohm and 1500 @ 2 ohms? What subs are you running? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2176 Registered: Dec-05 | Soundstream PCA 3500d |
