HSU STF-1 vs STF-2
Username: Icelax
Is it worth paying the extra $$ to upgrade to the STF-2?
Username: Project6
Post Number: 11080
Depends on your room size and how inadequate you feel the STF-1 would be for your needs.
Username: Icelax
My room is 15x20 but is also open to a kitchen area and stairs down to the first floor. Basically I wanted to see what kind of performance differences there is and if with the open area if I should go with the better sub.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1931
The STF-2 goes lower, to frequencies suited to action DVDs, where the STF-1 falls a little short. Plus your room is very large. I have a STF-3 in a similar space.
