Username: Icecreamman5687 Post Number: 29 Registered: May-06
Sunday, September 03, 2006 - 16:40 GMT i know this should be in the amp section but i think u guys give more advise and help.... was looking and i gots 2 type r's and was looking at a hifonics brutis amp...say 1600rms x1 at 1 ohm. if i bridge that do u think it would just fry my subs or would they take it cause i have heard but dont know if true that those alpines are always power hungry
Username: Delsole Post Number: 516 Registered: Feb-05
Sunday, September 03, 2006 - 16:42 GMT i would choose a different amp
Username: Delsole Post Number: 518 Registered: Feb-05
Sunday, September 03, 2006 - 16:44 GMT well they proly take i just wouldent push them to hard
Username: Icecreamman5687 Post Number: 31 Registered: May-06
Sunday, September 03, 2006 - 16:48 GMT any recomedations on what amp then im kinda lost..
Username: James1115 Ct
Post Number: 6474 Registered: Dec-04
Sunday, September 03, 2006 - 16:49 GMT I am with Joseph n this one. You will be lucky if that amp put's out 1200 watts.
Username: Bestmankind Los Angeles,
CA
Post Number: 5202 Registered: Oct-05
Sunday, September 03, 2006 - 16:49 GMT kicker kx1200.1
Username: Icecreamman5687 Post Number: 32 Registered: May-06
Sunday, September 03, 2006 - 16:51 GMT yah i would go with kicker but im on a tight buget...anything that will push them ok without spending alot....
Post Number: 6477 Registered: Dec-04
Sunday, September 03, 2006 - 16:53 GMT look on ebay
Username: Icecreamman5687 Post Number: 33 Registered: May-06
Sunday, September 03, 2006 - 16:54 GMT how about kenwood.....they overrated too.
Username: Basshead86 Google is your Friend,
FL
Post Number: 5292 Registered: Aug-05
Sunday, September 03, 2006 - 16:55 GMT kenwood is garbage....
Username: Icecreamman5687 Post Number: 34 Registered: May-06
Sunday, September 03, 2006 - 16:57 GMT just trying to get more knowlege from u guys....soo u think 1200rms wouldnt really hurt those type r's they do say 500rms-1500max for the subs...
Post Number: 6480 Registered: Dec-04
Sunday, September 03, 2006 - 16:59 GMT no 1200 is fine on them. What is your max budget on a amp?
Username: Icecreamman5687 Post Number: 35 Registered: May-06
Sunday, September 03, 2006 - 17:00 GMT ummm i have like around 200-250 max right now...
FL
Post Number: 5296 Registered: Aug-05
Sunday, September 03, 2006 - 17:01 GMT i would try to find a kicker, soundstream, or orion on ebay. that is your best bet
Username: Icecreamman5687 Post Number: 36 Registered: May-06
Sunday, September 03, 2006 - 17:02 GMT okk thnx
Username: Icecreamman5687 Post Number: 37 Registered: May-06
Sunday, September 03, 2006 - 17:08 GMT those subs are dual 4 ohms...any way to run them 1 ohm..
FL
Post Number: 5300 Registered: Aug-05
Sunday, September 03, 2006 - 17:13 GMT you have 2 dual 4 ohm subs??? you can wire them to 1 or 4 oms.
Username: Icecreamman5687 Post Number: 38 Registered: May-06
Sunday, September 03, 2006 - 17:16 GMT okk yah that helps...im looking at soundstream....thinkin i might con the parentals into pichin in some money
FL
Post Number: 5302 Registered: Aug-05
Sunday, September 03, 2006 - 17:21 GMT always a good thing.
Post Number: 6483 Registered: Dec-04
Sunday, September 03, 2006 - 17:57 GMT if they pitch in some money spring for the kicker
