JL System Advice
Username: 20la20
Franklin, TN U.S.
Post Number: 142
looking into getting a JL system...2-3 12s...want to run them off an eD nine.1 but am open to suggestions...let me know of good sub configs with this amp
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 805
what do you want sq sql?
Username: Delsole
Post Number: 464
mabe a w7
or a 13w6v2 that would rolly be a good match
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2737
the W6v2's are my fav subs by JL Audio and some of the best SQ subs around.
W7's are louder and boomier (is that a word?) then the W6v2's and imo, not worth the money when compared to other brands.
W3v3's i haven't heard yet, but are suppose to be nice. they are mass produced over seas though...so are the W1v2's which are the entry level stuff. doesn't mean they are bad, almost anything my JL will be a good choice.
Username: Delsole
Post Number: 482
get 2 12w6v2's
Username: Illuminator
Post Number: 4738
The 12w7 isn't as 'boomy' as the 13w7, and it really isn't boomy at all if you go by JL's recommendation and cut any bass EQ settings below 125Hz. Just my opinion.
Username: Tjmutlow
Post Number: 2750
before you buy 3 of anything, make sure you get the right ohm load config subs for the amp.
