OT: Fixing rust
Username: Alias747
MN
Post Number: 1207
My 91 accord has 3 spots where it is rusting. All of them are on the back wheels wells (go figure, they are infamous for rusting there.) Anyway, I picked up some bondo and fiberglass repair kits. Does anyone have any sites that shows how the best way to go about repairing these spots? I know it won't last forever but I kinda wanted to fix it for the short term. Any help would be great thanks!
Username: Tutonka
Marathon, Florida
Post Number: 40
just knock out all the rust with a grinder etc. and then clean it,bondo it,LET IT DRY,then sand it down with a fine grit sandpaper...nothin to it
