Silver Member Username: Hnic_menPost Number: 107 Registered: Oct-05 | hey guys im planing on gettin a system 2 kciker cvr's 12"Impedance: 2 or 4 Ohms DVC 400watt rms each and a kicker amp 850 watt rms now it says RMS Power Output: 295W x 2 @ 4 Ohms can someone explain to me what this means, does it mean that 1 speaker is going to be gettin 295 watt @ 4 ohms from 1 channel of the amp? and if so how can this be since the amp is 850watt rms shouldnt it be gettin 425watt from 1 channel? and what are the differnce with 2 and 4 ohms. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2111 Registered: Dec-05 | less impedance= more output power (this can change for example JBL amps) the amp is gonna put 425x2 at 2 ohms. what you need is 2 CVRS dual 2 ohm and a kicker zx750.1 and wire it to a 2 ohm load www.the12volt.com hit the link woofer wiring read this: www.bcae1.com www.wickedcases.com |
Silver Member Username: Hnic_menPost Number: 108 Registered: Oct-05 | so that's 425 divied by 2 which is 212.5 rms watts per speaker? also y would i want a mono block amp which is 1 channel for 2 speakers, unless u mean wire the speakers in series which is not going to be power full like parallel, unless i can wire them paralle. |
Gold Member Username: StnorrisIA US Post Number: 1221 Registered: Apr-06 | lol |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2120 Registered: Dec-05 | read the links please |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5128 Registered: Aug-05 | good post up there julio!! |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2130 Registered: Dec-05 | earning some good reputation^^^^^lol... |
