RF amps....
Username: Atllefty12
Pinellas, Fla.
Post Number: 253
Rate the new RF power series amps on a scale of 1-10... 10 being the best.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2088
9 or 10 for quality... they're expensive but they worth it
Username: Suleman36
Maryland U.S.A.
Post Number: 4029
Same here, 9-10 for quality and power plus they are underated. Excellant amps
Here is my POWER 1000
Username: Caraudio
Toronto, Ontario Canada
Post Number: 693
I got the T3002 for 250 Canadian good buy? THe power serise amps around ym area are going for 400 dollars canadian plus:| Ive been told there TOP NOTCH things.
Username: Tremor1127
Post Number: 70
MO, thats an awesome amp, you can run every speaker in your car with it lol... what is the real wattage from that amp?
Username: Caraudio
Post Number: 694
ny word on the t3002?
Username: Drsmith
Montana USA
Post Number: 253
10 my t1000 puts out 1657 watts ay 1 ohm and it looks tight which model were u lookin at andrew
Username: Caraudio
Post Number: 696
I dont get why their "rated" is different then"actual" How did they rate these amps in the first place?
Username: Drsmith
Montana USA
Post Number: 254
they basically just have them benched b4 they leave the shop thats what the little CEA certified stamp is about. take my amp for example some are tested at like 1300 watts so if they called it a RF 1500 it would be an overrated amp but since they call it a 1000 they are all underrated its makes them look better
Username: Juliob
Post Number: 2094
you bought a good model
Pinellas, Fla.
Post Number: 254
the t40001bd lol, it puts out 4465 x 1ohm
Username: Drsmith
Montana USA
Post Number: 270
sounds nice where is it online that ur looking at it also what r u gonna be pushin with that
Username: Camaro823
British Colu... Canada
Post Number: 665
MO, that amp is awesome, how much you pay ?
Username: Suleman36
Maryland U.S.A.
Post Number: 4030
JC / I bought it authorized for under $700 thru ebay from a authorized dealer in delaware. IT was in packaged from RF.
Username: Camaro823
Post Number: 668
Thats awesome, its a gorgeous amp.. have you hooked it up ?? if so hows it sound ??
