New member Username: 3rdcoastmexicanHouston, TX US Post Number: 2 Registered: Aug-06 | say what do ya think i should do either keep my two 15" kicker cvr or trade them and get two 12" kicker solo-baric L5? ive got one blade exxtreme 3500 watts amp to each woofer if that helps? |
Silver Member Username: KenwaPost Number: 203 Registered: May-04 | Keep the cvr, L5s are junk imo. |
Silver Member Username: DelsolePost Number: 444 Registered: Feb-05 | cvr's |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8732 Registered: Jul-05 | "blade exxtreme 3500 watts amp" WTF is that???? and L5's are junk |
Silver Member Username: FrkkevinLake Worth, Texas US Post Number: 500 Registered: Nov-05 | Yea.. never heard of that amp. The only Blade amps I've seen were not even rated over 275 @ 4ohm. It makes me wonder what kind of power your actually getting from that amp... |
New member Username: 3rdcoastmexicanHouston, TX US Post Number: 3 Registered: Aug-06 | this is the boss blade exxtreme 3500 im talkin about. ive got two of these. Max power 3500w RMS power, 4ohm@.01% THD 1200w x 1 RMS power, 2ohm 1700 x 1 RMS power, 1 ohm 2000w x 1 1/2 ohm Stable stereo Power n/a Frequency response (+/- 3dB) 9Hz-250kHz Signal-to-noise ratio >105dB Channel separation >90dB Low pass Crossover 50Hz-100Hz High pass Crossover 120Hz-720Hz Bass boost 0-+18dB Bass boost Frequency 45Hz-100Hz Dimensions, LxWxH 17 1/8" x 11 5/16" x 2 3/8" |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4864 Registered: Aug-05 | 20002RMS at 1 ohm aye?? i find that rating to be somewhere in the 14.4V range. lol let me put it like this....if those amps put out anywhere NEAR their rated power....you will need a bigger charging system. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4866 Registered: Aug-05 | 2000wRMS***** friggin typo..... |
New member Username: 3rdcoastmexicanHouston, TX US Post Number: 4 Registered: Aug-06 | ok but what do u think about the amp itself? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 5032 Registered: Oct-05 | ^^^^^i love that name man. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8733 Registered: Jul-05 | "ok but what do u think about the amp itself?" TRASH!!! |
Gold Member Username: Thomas_gNM Post Number: 1621 Registered: Oct-05 | Da mota iz right here mayn!!!! I would keep tha cvrs.... |
New member Username: 3rdcoastmexicanHouston, TX US Post Number: 5 Registered: Aug-06 | well tell me whats your idea of a better amp then |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8735 Registered: Jul-05 | in what budget and power range?? |
New member Username: 3rdcoastmexicanHouston, TX US Post Number: 6 Registered: Aug-06 | anything to bring da full potential of two 15" CVRs |
Silver Member Username: DrsmithMontana USA Post Number: 250 Registered: Nov-04 | buy my RF T1000 puts out like 1200 something at 2 ohms 15" cvr's are 500 wrms so its would work depending on VC config |
Bronze Member Username: Thed42Post Number: 12 Registered: Jun-06 | I think if I sh1t in the small end of a cone it could sound better than anything made by kicker |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 35 Registered: Aug-06 | ^^i think tht u dont no wut ur talkin about cuz kicker cvr's are actually pretty nice |
Silver Member Username: LoudonPost Number: 552 Registered: Jun-04 | and to be honest ... L7s dont sound bad they just dont sound good .. ok a straight spl sub isnt gonna have ne thing but average sq ne ways and btw ... a solo x sounds better then an L7 sq wise .. just from my personal expierience |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5068 Registered: Aug-05 | now there is a tidbit of knowledge. i would hope there most expensive square had the best SQ of the three garbage can lids. lol |
New member Username: 3rdcoastmexicanHouston, TX US Post Number: 10 Registered: Aug-06 | yall are all too technical about all dis stuff i just want something that can have my neighbors finally have a reason to call da cops on me and i wanna set off alarms and all that good stuff. but nawwww ya just wanna make everything all technical. |
Gold Member Username: StnorrisIA US Post Number: 1223 Registered: Apr-06 | haha. first of all are your subs dual 2 ohms, or dual 4 ohms. depending what they are, i would look at a kicker zx1000 or any of the kicker amps around 1000rms. ur gunna be looking at about $380 shipped on ebay though. or just buy that rf amp, if ur subs are dual 2 ohms. |
Bronze Member Username: 3rdcoastmexicanHouston, TX US Post Number: 15 Registered: Aug-06 | there 4 ohms |
Gold Member Username: StnorrisIA US Post Number: 1226 Registered: Apr-06 | ok. your amp will need to be putting out the most power @ 1 ohm then. so look for any amps that say around 1000rms @ 1 ohm. |
Bronze Member Username: 3rdcoastmexicanHouston, TX US Post Number: 16 Registered: Aug-06 | yea i already got two of them boss amps. they have 2000rms @ i ohm. the picture and specs are up top that i posted a couple comments ago. |
