Silver Member Username: Steve_collinsPost Number: 168 Registered: Dec-05 | hey ok so i have about 250 dollars to spend on a 15 and i wanted to know what the best ub would be for spl. thanks a lot |
Bronze Member Username: Allstar13Houtson, Texas Post Number: 22 Registered: Jul-06 | these probley arnt the best but not bad a Kicker L7 or CVX closer to 300 but u might beable to find one somewhere for 250 |
Bronze Member Username: Matt_stuPost Number: 68 Registered: Jun-06 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14808 http://www.ascendantaudio.com/arsenal15specs.html theres plenty more choice out there just shop around |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1858 Registered: Feb-06 | wow are u sayin kicker square subs????? hahah i rather get the bahns aw1206t will sound much better and have alil bit f more spl plus aloot cheaper |
Silver Member Username: Steve_collinsPost Number: 169 Registered: Dec-05 | cool any others? thanks |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1860 Registered: Feb-06 | http://realmofexcursion.com/videos/Audiobahn/aw1206t.10.wmv those cost 120 for the 15 inch model and get really loud louder than solo barics square subs and sound alot better it wil last longer, but if u need sq the sound splinter rl-p will be your best choice |
Gold Member Username: CtmikeCt. Post Number: 1519 Registered: Feb-06 | i know mike loudon is selling a 15" aa ava for $250. |
Gold Member Username: CtmikeCt. Post Number: 1520 Registered: Feb-06 | oops, didn't see you wanted straight spl. but it'll still get plenty loud. |
Silver Member Username: Steve_collinsPost Number: 170 Registered: Dec-05 | oo are you selling a type r |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 766 Registered: Feb-06 | id get the L7s if i was you... |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1861 Registered: Feb-06 | do not get l7 worse sq, and its the most defective subwoofer on the market along with all square subs, my shops sells kicker and our most returned products its the square subs why??? the corner of the suround ripped, plus that cone square shaped make stress points on the woofer (the corners) the l7 get loud but not that loud avalanche yes its a super great sub but if u need a brand new u can get a sound splinter rl-p |
Silver Member Username: Steve_collinsPost Number: 171 Registered: Dec-05 | well so should i get the audiobahn i havent heard good things but its cheap or the ava or the rlp. would 2 12 type r be louder than all or cvr. thanks for all the help |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1862 Registered: Feb-06 | if u want a single sub set up a single avalanche or a rl-p will be fine both of them will get really loud and sound great since those too are sql drivers if ur going dual sub set up id get the aw1206t it will be louder than the type r's and cvr's but the type r will sound lil cleaner. but since ur going spl id get audiobahns do not get regular audiobahns cuz most of the bahns subs are crap but the falme q or the aw1206t get really loud and sound decent thats why i have them for daily drivin i got a sx but i dont use it cuz its too big i need space for my tools and stuff. |
Silver Member Username: Steve_collinsPost Number: 172 Registered: Dec-05 | well what would you do haha sorry. i dont know if i could do 2 audiobahn because i dont think my car could handle that much power |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1864 Registered: Feb-06 | back in the day i had my bahns with 400 rms each and it sounded great but i think u need to get th tl-p if u want a single sub set up |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 5058 Registered: Oct-05 | i'd take the L7 over any audiobahn. |
Silver Member Username: Big_fletchNewport, Ar, Ar United states Post Number: 524 Registered: May-06 | go 15 L7 they are made for SPL |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1866 Registered: Feb-06 | take the l7 and in a week ull be returning it and claiming your waranty |
Bronze Member Username: Allstar13Houtson, Texas Post Number: 27 Registered: Jul-06 | and then you get a new one no problem and i know plenty of people with L7s that last |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 5091 Registered: Oct-05 | lilrob if people are buying L7s from your shop and returning them in a week then there is a problem. you guys must be doing something wrong in the installs because i know alot of people who has used them for a long time. |
Silver Member Username: Crayola0Wisconsin Post Number: 678 Registered: Jun-06 | i know a guy with 2 15" l7's and his have been lastin pretty good hooked up to a hifonics XX colosullus. loud as h3ll!!! |
Bronze Member Username: BernymacRialto, CA United States Post Number: 65 Registered: Sep-04 | I got two 15in Type R's with box for 300. Probaly not the most spl I don't think. But contact me if your interested by any chance. |
