Username: Imalik Jackson,
New Jersey
Ocean
Post Number: 6 Registered: May-06
Sunday, August 27, 2006 - 16:54 GMT I need a bit of help, Im looking to buy a nice D class amp for 2 12 cvrs, should I go with the Hifonic bxi-1606 or Kicker zx400.1. Thanks
Username: Rick_ross Post Number: 418 Registered: May-06
Sunday, August 27, 2006 - 17:02 GMT definately get kicker over hifonics but y u gonna get the zx400.1 u need a zx750.1
Username: Adddisorder West palm,
Florida
Post Number: 650 Registered: Jan-06
Sunday, August 27, 2006 - 17:11 GMT kicker 750.1
Username: Big_fletch Newport, Ar,
Ar
United states
Post Number: 501 Registered: May-06
Sunday, August 27, 2006 - 17:20 GMT go kicker
Username: Rob_preg Royal oak,
Michigan
United states
Post Number: 481 Registered: Sep-05
Sunday, August 27, 2006 - 17:49 GMT im on my second generation of kicker amps now, and have nothing but good things to say about them.
Ar
United states
Post Number: 506 Registered: May-06
Sunday, August 27, 2006 - 19:08 GMT kicker amps are very underrated
Michigan
United states
Post Number: 492 Registered: Sep-05
Sunday, August 27, 2006 - 19:26 GMT for example, the kicker amps ive owned and their birth sheet ratings: kx350.4 - tested at 400w rms kx600.1 - tested at 710w rms zx200.2 - tested at 250w rms zx1000.1 - tested at 1170w rms and i can appreciate a company that doesnt bother printing "peak" or "max" ratings anywhere.
New Jersey
Ocean
Post Number: 7 Registered: May-06
Monday, August 28, 2006 - 15:13 GMT Thanks guys, The 400.1 is in the range I was looking to spend. Rick Ross I will save a bit more for the 750.1 The 400.1 is too small for 2 12 CVR's??
Michigan
United states
Post Number: 507 Registered: Sep-05
Monday, August 28, 2006 - 16:07 GMT i'm not rick ross, but the kicker zx400.1 would be great for a single 12 cvr, but not for a pair. it would be in your best interest to wait alil longer, save your money, and get the zx750.1 if you want to get the most out of those compvr's. and they are dual 2 ohm, correct?
New Jersey
Ocean
Post Number: 8 Registered: May-06
Monday, August 28, 2006 - 19:28 GMT Dual yes but 4 ohm, I will save a bit more for 750.1
Username: Ctmike Ct.
Post Number: 1509 Registered: Feb-06
Monday, August 28, 2006 - 19:38 GMT no, the 750.1 wont work for a pair of dvc 4ohm subs. you need a 1ohm stable amp to run your subs.
Michigan
United states
Post Number: 520 Registered: Sep-05
Monday, August 28, 2006 - 19:44 GMT ^^ correct. you will need a pair of 2 ohm dual voice coil subs to get the most out of that amp. a pair of dual 4 ohm subs wont work well, each sub would only get roughly 190w rms.
New Jersey
Ocean
Post Number: 9 Registered: May-06
Monday, August 28, 2006 - 20:26 GMT OK Thanks guys
Username: Juliob Santo DomingoDominican Re...
Post Number: 2046 Registered: Dec-05
Tuesday, August 29, 2006 - 01:43 GMT if he owns a pair of 4 DVC CVRs i'd get hifonics 1206d cuz it will work good... those kicker amps can't power those subs if they're dual 4
New Jersey
Ocean
Post Number: 10 Registered: May-06
Tuesday, August 29, 2006 - 17:48 GMT Looks like the Hifonic will work better since its 1 ohm stable.
Florida
Post Number: 685 Registered: Jan-06
Tuesday, August 29, 2006 - 17:55 GMT kicker can run at .5ohms daily 1ohm is fine
New Jersey
Ocean
Post Number: 11 Registered: May-06
Tuesday, August 29, 2006 - 20:51 GMT Two4 fifteens said I would only be gettin 190rms, with the dvc 4ohm with the 750.1
Username: Troy81 Tavernier,
Fl
Us
Post Number: 1017 Registered: Mar-06
Tuesday, August 29, 2006 - 21:03 GMT memphis
New Jersey
Ocean
Post Number: 12 Registered: May-06
Tuesday, August 29, 2006 - 21:07 GMT Memphis amp?
Post Number: 2073 Registered: Dec-05
Tuesday, August 29, 2006 - 21:59 GMT i think the memphis would be too much power... cuz they're underrated... if you can find one go for it and control the gain. But you just need a 1000w rms amp at 1 ohm for the job
