Best way 2 wire 2 4OHM SINGLE VOICE COIL SUBS TO
Username: Caraudio
Toronto, Ontario Canada
Post Number: 689
A8002V amp to get most out of the amp. Right onw i have each sub going into their own channel and its pretty loud but not to bad.
Can i make it a 2ohm load and bridge the amp? It does say it is 2ohm stable.
Username: Suleman36
Maryland U.S.A.
Post Number: 4024
Wire the subs in parellel to get a 2 ohm load to match your amp.
Username: Tweeker
Post Number: 395
nooooooooo ^^^ dont do that unless you want your amp to fry LOL you cant bridge it at 2ohms only at 4ohms you needed to get the a800V
Username: Suleman36
Maryland U.S.A.
Post Number: 4025
If your amp is 2 ohm stable then yes you can wire the subs in parallel. If not then you will need to find an amp that is 2 ohm stable.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2056
4 ohm SVC to each channel will create a 4 ohm load. 2x200w
the a8000v would be 800x1 at 2 ohms (best amp/way to wire
Username: Tjmutlow
Post Number: 2728
wire 1 sub per channel or buy the 8000v amp....
