Bronze Member Username: LongbluesquidPost Number: 45 Registered: May-06 | i tried everything at it says files in .aac cannot be converted anyone know how to take these songs i purchased from itunes and put them onto a cd |
Bronze Member Username: Nyyfan13VA USA Post Number: 73 Registered: Jul-06 | are u making a regualar cd or an mp3 cd? |
Bronze Member Username: LongbluesquidPost Number: 46 Registered: May-06 | a regular cd |
Silver Member Username: GrebnereonPost Number: 140 Registered: Mar-06 | it wont even let ya burn em onto a regualar cd? |
Bronze Member Username: Nyyfan13VA USA Post Number: 74 Registered: Jul-06 | well i dont know what to tell you about a regular cd. is your computer even reading that u have the blank cd in? |
Bronze Member Username: LongbluesquidPost Number: 47 Registered: May-06 | no it will let me its just the songs wont be readable on my stereo i want them to be converted into mp3 format |
Bronze Member Username: Nyyfan13VA USA Post Number: 75 Registered: Jul-06 | this is what i did to convert my songs to mp3 format. if you want your songs to be in a mp3 format you have to download a program to do it. i used the program called 'Switch'. http://www.nch.com.au/switch/plus.html thats the website, just download the demo version, its free. after you download it, there souhld be directions on how to use it, its real easy. again, this is what i have done and do whenever i make a mp3 cd. im sure there is an easier way to do it that i dont know of because i am not the best with computers. hope this helped you in anyway. |
Bronze Member Username: Nyyfan13VA USA Post Number: 76 Registered: Jul-06 | it didnt bump up |
Bronze Member Username: Nyyfan13VA USA Post Number: 77 Registered: Jul-06 | still never bumped |
