Bronze Member Username: Thumping_corsicaSaginaw, miUnitd states Post Number: 12 Registered: Aug-06 | hi i have a sony cdx-f5710 hu and a liht. audio s2.600.2 amp and im having trouble like with the pre out voltage crap from hu and stuff(confusing) so if someone could just tell me where to put the gain at that would be real nice.thx ps-are the pre outs for amp in back of hu the 2 dangling chords? |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 632 Registered: Jan-06 | yeah, im pretty sure its 2volts you can use a dmm to check. i wouldnt turn your volume past 3/4 because that is about the cliping point |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4950 Registered: Oct-05 | how many wrms is that amp? also what is the ohm load of the sub. use this site to get the voltage you need. http://www.subwoofertools.com/forum/setgain.asp after you find what voltage you need, get yourself a digital voltage meter and connect it to the sub connecter on the amp. then just simply adjust the gain until you get your target voltage. the way i do it is i get a 50hz test tone and play it at 3/4 volume. turn off bass boost and set your hu eq at 0. then i start turning the gain on my amp until my target voltage is matched. |
Bronze Member Username: Thumping_corsicaSaginaw, miUnitd states Post Number: 14 Registered: Aug-06 | what about the gain on the amp?? where should i put that? |
Bronze Member Username: Thumping_corsicaSaginaw, miUnitd states Post Number: 15 Registered: Aug-06 | i have two type r's (500 rms each) they are 4 ohm dvc's (im running the subs parreleled so its a 4 ohm total load to the amp) |
Bronze Member Username: Thumping_corsicaSaginaw, miUnitd states Post Number: 16 Registered: Aug-06 | the amp is 600 rms at 4 ohms |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4953 Registered: Oct-05 | i am talking about the gain on the amp. don't worry about what your preout voltage is on the hu. as long as you match it up to your target voltage you will be fine. okay i put in the info in to that site and it gave me 49volts. just keep turning the gain back and forth until you see 49v on your digital voltage meter. you have to set that digital meter to ac. |
Silver Member Username: Van_manBoston South, MA Post Number: 856 Registered: Mar-06 | Nice link Chad. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 688 Registered: Sep-05 | In that site do i enter Watts or RMS watts? |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 645 Registered: Jan-06 | rms |
