IS IT WORTH BUYING VIEWSAT??
Username: Pannu16
Post Number: 88
IS IT GONNA LAST FOR ATLEAST 4 MONTHS, WAT DO U SAY GUYS, I AM THINKING OF BUYIN IT FROM ebay!! WAT DO U SAY GUYS!!
Username: Dailce
Post Number: 21
I got a Views&t, I find that it has a much better EPG than cool*at, looks cooler and more professional. I even think the picture quality is better then cool*at - plus they got a fix :-)
Username: Peabody67gto
I just gout my Extreme from Ebay for $144 and I think it will last much longer. I am sure it will go down again but will all the support Viewsat has it shoud take a short time from them to come up with the bin. I also have a Pansat that I was tired waiting for the fix and if it does come out I can always sell it with a working fix or use it in another room. The price of VS should go up soon so I would buy one ASAP. I got a very good price on Ebay for $144 Shipped..
Username: Vinidomine
Post Number: 163
VS Xtreme is an excellent receiver and is right there with the coo1sats as far as speed and quality. compared to a pansat 2700A is much faster with a much more advanced video interface. I own ONE VS Xtreme. Have no complains.
As to my plan of action, Im giving Pansat and Coo1sat two more weeks. If nothing happens there Im selling all two coo1sats and the pansat 2700a and buying 3 VS xtremes.
Now... keep in mind... I also do FTA with a 36" dish so even without DN, Im still watching TV.
Personal opinions will vary. This is my 2 cents..
Vini
Post Number: 164
Also... do not buy Viewsats from SAT THINGS from TOTAL FTA. They are practicing a very greedy price gauging at their end. The units were selling for just around 130 ~ 139 bucks. Within one week of the fix... the price went up the roof to a big 169.99 per unit. a $30 dollars price increase in just 5 days.
Keep looking on ebay... is your best bet.
Vini
Username: Herb_toker
POTTSVILLE, GRASSLANDS GREEN--LAND
Post Number: 76
BUYERS BEWARE.No guarantee that theres gonna be a fix when the next ecm happens. AND IT WILL HAPPEN GUARANTEED.
It was 40 days for them last time.Remember that.
GUARANTEED your all in for a rude awakening.
WHY do you think there so f'n cheap?????It sure as hell aint there generosity.
Suppose there trying to unload them as fast as possible???
Post Number: 77
ON THE POSITIVE SIDE:
One month of a package like that.You cant even buy it.If you could it would be several hundred a month.
Hope you get your month.
Username: Hcaoc
How about a viewsat platinum?
Post Number: 79
Are you offering? Sure thanks. Send it to me.
Username: Cucon1
heh! One month of open TV programing is worth a lot more than the $149 you pay for the VS !!!
Username: Bighips69
Nassau, None Bahamas
Hi guys, I'm from the Bahamas. Do any of you have the codes for the pansat 2700A. I'm desperate. (Help)
Post Number: 82
Yeah dan one month is worth several hundred if you could even buy it.
But would you pay 149.00 for one month???And for how many months would you pay that?
On one hand if you buy now you get the longest run.
On the other if it goes down the day after you click that buy now button??????
Like i said hope you get a month.
Its been 10-12 days now????
Username: Johnner
Miami, Florida
Post Number: 467
The long anticipated VIEWSAT PVR7000 is finally here! It took us a little longer to release the PVR than we anticipated. We wanted to make sure that the customer would be getting a high quality product. This is a dual tuner PVR! Any standard IDE hard drive can be easily installed through the front access panel. This new addition to the Viewsat product line is sure to be a winner.
Features
Technical Specifications
Fully MPEG-2 & DVB Compliant
2 Tuners
Watch and record
Dual recording
Time-shifting
Front panel easy hard drive access (hard drive not included)
Compatible with up to 2000 Gig hard drive!!!
Front panel card reader
MP3 (MPEG-1 Layer3) decoding
Powerful trick mode supported
Playback of the selected region repeatedly
Front Panel USB 2.0 supported for fast PC interface
Dual Decoding (PIP-Picture in Picture)
160MHz ST processor
Set to Set Download (Main Program, Channel Data)
Input Frequency 950 ~2150MHz
4:3, 16:9 Letter Box
22KHz Switching Control
Various LNB Polarity Control
Supports Electronic Program Guide (EPG), Picture in Graphic (PIG)
Supports SCPC & MCPC from C / Ku-band
Fast Booting & Auto Scan
Quick Channel Changing
Max 8000 Channels (TV & Radio) Programmable
User Friendly 256 Colors OSD & Easy GUI
Multi OSD Language supported
Favorite Channel List editing
Master PIN Code Function & Parental Lock Function
Optical Output for Digital Audio
Window based S/W Download Program Supported by RS232 Serial Port
S-VIDEO Output
RF-Modulator Output
Power Switch
S/PDIF Output for Digital Audio
9 RCA Output for Video (Twin), Audio L/R (Twin), Component
Zoom function
Hardware based Blind Scan
DiSEqC 1.0, 1.1, 1.2 and USALS (1.3) Compatible
Photo Album
Power Supply
Type: SMPS
Input Voltage: AC 95V~240v 50Hz / 60Hz
Fuse Rating: 250V/T2A
Tuner
Input Frequency: 950 ~ 2150MHz
Input Signal Level: -65 ~ -25dBm
Input Impedance: 75ohm Unbalanced
Connector Type: 'F'Type Female
LNB Power Supply: 13V/18V, Max 500mA with Short Circuit Protection
22KHz Tone: Frequency 22± 4KHz, Amplitude 0.6±0.2Vpp
DiSEqC: 1.0 , 1.1, 1.2, USALS(1.3) Compatible
Channel Selection: PLL Frequency Synthesizer
Demodulator
Type: QPSK Demodulation (DVB-S)
Symbol Rate: 1 ~ 45 MS/s
Inner FEC: Viterbi Convolutional Coding
Rate 1/2, 2/3, 3/4, 5/6, 7/8
Outer FEC: Reed Solomon Coding(204,188) T=8
Video Decoder
System Decoding: MPEG-2 ISO/IEC 13818-2
Profile and Level: MPEG-2 MP@ML
Data Rate: 1 ~15 MB/s
Video Formats: 4:3(Normal) & 16:9(Widescreen)
Audio Decoder
System Decoding: MPEG-1 ISO/IEC 11172-3 Layer I & II
Audio Mode: Mono, Dual, Stereo, Joint Stereo
Sampling Frequency: 32, 44.1, 48 KHz
Audio/Video Output
Audio Output: 2 RCA Cinch
Video Output: 1 RCA Cinch
Digital Audio: 1 S/PDIF (Optical)
S-Video: 1 S-VIDEO
COMPONENT: 3 RCA Cinch
RF Modulator
Modulator Output: CH3~4
Video Type: NTSC
Output Connector: "F" Type Female
Ant. IN Connector: "F" Type Female
8. Serial Data Interface
Signal: RS-232, Max. 115200 bps
Connector Type: 9 Pin D-Sub (male)
Embedded Descramble
X Crypt Conditional Access System
Processor
160Mhz ST processor
Memory
Flash: 4MByte
SDRAM: 40MByte (System: 16MB*2, A/V: 8MB)
EEPROM: 16Kbit
Username: Johnner
Miami, Florida
Post Number: 468
8/23/06--> Working: Viewsat PVR7000
Username: Hcaoc
No, I was asking about the platinum vs. the extreme in terms of quality of product. I have a pansat, but have purchased a viewsat platinum.
Post Number: 83
Good choice for now harley.
Username: Mrcharley
Port norris, N.j. U.s.a.
Post Number: 10
i think the best move if you already own an fta receiver is to go to the card format. this way you have the best of both worlds
Username: Johnner
Miami, Florida
Post Number: 470
viewsat platinum:
Well I programmed one not too long ago and I can tell side by side Pansat in my opinion is more user friendly.
A quick example when autoroll is working in Pansat a #% would come up that lets you know that is working, on the other hand Viewsat just offers a black screen which is a down side, in another hand the guide on a Viewsat is faster and more reliable.
Another feature that Viewsat has over Pansat is that you can scan multiple SATs simultaneously, saving you time.
And of course the most famous of all: Viewsat has being in the lead with support in the last two times, especially in the last one having the solution not only first but still today Pansat doest not have it.
The way you program it differs a bit too but is basically the same. On the Pansat you Turn On the receiver and send the file from the PC to the receiver.
On a Viewsat you keep the receiver Off send the file and then turn on the receiver.
Little thing that make them different but in the end what is most valued from a FTA receiver is support and Viewsat has prevent that it delivers.
Post Number: 84
Viewsat has "prevent" that it delivers.
Your right they prevented for 40 day that they could deliver.
Just kidding.
Notice theres a lot of new receivers out that are running basicly the same hardware.Most the old receivers are running st5518 cpu and may never come back.The newer sets stand a better chance but time will tell.
Username: Johnner
Miami, Florida
Post Number: 471
(Proven) that was what I tried to say!
Why do you think st5518 CPU are not coming up? Is it that much different from the new ones in hardware?
Username: Hcaoc
Thanks for your help. As said, just purchased the viewsat platinum due to the current problem with pansat. I personally have never programmed one, as a friend usually does the pansat. Any help with the ins and outs of the process with viewsat is greatly appreciated.
Username: Mrcharley
Post Number: 11
fta is like a poker game viewsat has won this hand and is raking in the pot. to quote kgb in the movie rounders "give that man his money"
Post Number: 86
My theory is conspiracy.To make you by new hard ware.Can they make it work?Probably.
Most likley they dont have the power to run the software.Im guessing.Same reason the newest games wont run on your computer.Your receiver, basicaly a computer and more.Some of the newest receivers are coming out with hard drives so youll have a built in dvr too.
There must be 5 new receivers in the last 30 days on flea bay in the last 40 days.Coininsedance?
Username: Jmill1948
Chester, Va Usa
Post Number: 872
this is true....it will happen it is only testing equipment you must remember that...........
Username: Pannu16
Post Number: 90
thanx for the feedback ppl
Username: Jurj1
Post Number: 146
If you look at it from a supply and demand perspective, and considering they are pretty much the only game in town, the VS receivers should be selling for as much as or more than plastic right now, but they are not. This leads me to believe they are trying to unload as many as they can before the next DN hit, because they won't be able to fix it anytime soon. If I was a non-VS FTA owner, I would seriously reccomend buying plastic before buying VS, and simply wait for your FTA fix.
Username: Arvalan
Post Number: 9
what ia the meaning of "ECM" ? please
Username: Johnner
Miami, Florida
Post Number: 477
ECM (Electronic Counter Measure)
Username: Lroy
Post Number: 21
Electronic Counter Measure.........
Username: Simikang
Post Number: 44
hxxp://cgi.ebay.com/VIEWSAT-PLATINUM-BUY-FROM-THE-BEST-PERFECT-FEEDBACK_W0QQitem Z300020446089QQihZ020QQcategoryZ32845QQrdZ1QQcmdZViewItem
viewsat platinum very very good deal comes with card reader diseqc switch and a free cable and free shipping only 149!!!!!!!!!!!!!!!!!!!!!!!
Username: El_chido
Post Number: 28
DOES ANYONE KNOW HOW TO UPDATE A VS2000 EXTREME
Username: Birdwatcher
Post Number: 346
well if they f.uck it up for viewsat again they will probably get the fix out before pansat
