Username: Baalz159 South Plainfield,
New Jersey
Post Number: 21 Registered: Aug-06
Thursday, August 31, 2006 - 00:33 GMT Title says it
Alabama
U.S.
Post Number: 8740 Registered: Jul-05
Thursday, August 31, 2006 - 02:40 GMT trash
Username: N2audio Lawrence,
Ks
Post Number: 976 Registered: Mar-04
Thursday, August 31, 2006 - 03:00 GMT OK on a budget. Around here, if it's not Zapco, JL, Kicker, or a few other well known brands, it's junk. Kole is a Power Acoustik sister, and in many cases they probably share the same boards. You can add SPL to the Kole, PA list too.
Username: Kissdaredevil Post Number: 14 Registered: Aug-06
Thursday, August 31, 2006 - 03:07 GMT personally i wouldn't say there junk but there not top of the line or anything. they are made by power acoustik like optidriven said. if you did buy one buy a class d. but for the same amount of money you could buy a better brand.
Username: Juliob Santo DomingoDominican Re...
Post Number: 2096 Registered: Dec-05
Thursday, August 31, 2006 - 19:18 GMT i'd only buy like 2 kole audio amps... those ones with the same board of PA a3000db (2000w rms+) and a2400db (1800w rms)
