Trutech tt1620 HELPPPP
Username: Tami001
i have a trutech 1620 dvd recorder and i can't figure out hhow to work it along with my digital cable box. i think i have connected right but when i try to record nothing happens. so if someone could walk me through hooking it up with my tv and cable box it would be greatly appreciated.
Username: Samijubal
Post Number: 3060
Connect the box to the recorder with s-video or RCAs and set the recorder on whatever input you used. If using s-video, you still need RCAs for audio.
Username: Tipstir
Post Number: 74
You'll should get another digital cable box for it if you want to record manually. One Digital cable box for your TV and one for your Target brand DVD Recorder which is really a Cyber model.
