New member Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 8 Registered: Aug-06
Posted on my budget on an amp for my 2 type r 10's(ported boxes, 4 ohm dvc's) would be about 300 bucks (i can use ebay to) thx a lot.. p.s.- would 5 gauge power cable be big enough? |
Gold Member Username: Basshead86
Google is your Friend,
FL
Post Number: 4703 Registered: Aug-05
Posted on wrong section. try Kicker. they are relatively cheap on ebay. look for a kx1200.1 |
Post Number: 10 Registered: Aug-06
Posted on ok thx a lot... |
Gold Member Username: James1115
Ct
Post Number: 6362 Registered: Dec-04
Posted on good call on the kicker if you can find it for that price. I am sure you can on ebay. |
