Bronze Member Username: FatkidPost Number: 23 Registered: Dec-05 | how do i find the displacement of my sub when building a box |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4904 Registered: Oct-05 | usually the spec sheet that comes with your sub tells you. if not you can always check online. what sub are we talking about? |
Bronze Member Username: FatkidPost Number: 24 Registered: Dec-05 | http://www.fusioncaraudio.com/products.php?region=&action=view&product_id=25 here is teh sub on there website it doesnt say the displacement |
Gold Member Username: James1115Ct Post Number: 6303 Registered: Dec-04 | its prob around .075-.09 given its size, and magnet weight. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4715 Registered: Aug-05 | agreed...most people use .1 if they aren't sure. |
