I bought a Motorolla DCT2224 digital cable box on ebay. I did a factory reset and it now displays '0'. I called comcast to send an INIT hit to re-initialize the box, which they did. It did not work. Am I SOL? This box is in bedroom, I have a Comcast HDTV box in another room and want to make sure I don't interfere with its reception. thanks
I did a factory reset: On the front of the box, hold in the power and select buttons for 10 seconds, then reach around and unplug the power while still holding in those two buttons. Wait another 10 seconds then plug the power back in and wait another 10 seconds then let go of the power &select buttons. It should then go to "0", if it does that is good. Just call your cable company and tell them your box just has a "0" on the front and they should then send an INIT hit to re-initialize the box.
