RMS watts
Username: Lyndal34
BrisbaneAustralia
Hallo, complete novice here. Iam selling my teac floor speakers, and was asked how many RMS watts they are? Doesn't that depend on the amp being used? The only info I have about them as there are no stickers, is that they are 8-16 ohms, have tweeter, s.woof and woof, are 2 feet high and have a massive sound. My amp is apparently 185 watt consumption, and on a volume scale of 1 to 10, 3 is massively loud, but clear in bass, medium and treble. Can anyone help me?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9049
The amp has the watts, the speakers use those watts. The person asking the question is probably used to car audio, where massive numbers are desired. The numbers mean nothing, but they are desired. The electrical wattage consumption of your amplifier also means nothing in regard to how many watts it produces into a loudspeaker load.
Since there are no numbers which adequately describe what you've been asked to provide, I would suggest three possible answers. 1) My amp does 185 watts and they play loud. 2) How many watts are you planning to use? The speakers should handle that if you don't distort the amplifier. I've played very loud and they aren't damaged in any way. 3) I've been told there is no proper answer for that question. Would you like to bring some music over and listen to them play?
Username: Lyndal34
BrisbaneAustralia
Thank you for your help Jan, much appreciated.Your recommended answers are just what I should do, so thanks again. This question has sparked an interest to understand more about these things.
Cheers!
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1785
To quote[1] someone on the forum:
When taken literally, you are quite literally incorrect, sir.
[1] https://www.ecoustics.com/electronics/forum/home-audio/256379.html
Username: Nuck
Post Number: 3938
I see no direct coorelation between consumption and output, Peter. Certainly nothing linear. If you are going to the way outer limits, well ok, an amp consuming 400w is not likely to deliver 5000.
Can you expand on that?
Username: Nuck
Post Number: 3939
https://www.ecoustics.com/electronics/forum/home-audio/261981.html
Thats a 50 amp breaker, folks!
Post Number: 1789
And I agree with you on that.
That would be correct too. So you see, saying that it means nothing is incorrect.
I also find it funny when a receiver's specs claim 7x100W and yet the same receiver's back cover also claims a power consumption below 350W. Averaged over time, the energy output must be equal to the energy input.
Username: Nuck
Post Number: 3946
Whether the ratings are continuous or peak as well. 100x7 may be achievable peak(with caps donating the voltage to achieve 700 on paper), once every few seconds or so.
Post Number: 1792
Yup.
Username: Nuck
Post Number: 3949
Actually it must be much less.
Thermal losses and all.
Wattage calculation must also be considered.
Input is va, output is so variable.
Dallas, TX
Post Number: 9067
My statement is absolutely correct. This, however, is not the place to argue the fact, particularly with pg. If someone wants to dispute my logic, you can place a reasonable argument to the contrary, not just a statement that I am incorrect, on another thread and not hijack this thread. I'm not about to engage in another p!ssing contect with anyone who cannot argue the message and wishes only to attack the messenger.
Post Number: 1795
.(This space intentionaly left blank; I'm not too sure why.)
Nuck, I was talking thermodynamics when I said equal. The energy drawn from the electrical outlet must be equal to the sum of the energy sent to the speaker (or dissipated in the speaker cables) and the energy dissipated as heat by the receiver.
Of course you think that your statement was correct, otherwise why would you have said it. But the fact that you think it so doesn't make it so.
I already have, as requested by nuck. See above. The mere fact that one is limited by the other implies that your statement was incorrect. But it's not a big deal Mr Vigne. I don't think that anyone is going to think any less of you for thinking otherwise, but arguing against basic thermodynamics isn't likely to make you look better to your public. Have a good night!
Dallas, TX
Post Number: 9068
You can neither read nor think logically, pg. That's too bad.
Username: Nuck
Post Number: 3960
just another day in paradise.
Tell ya what, kids.
When I hook up the BIG BAD AMP tomorrow, I will fill y'all in on the in's an' out's, k?
I can tell yer hearts' are all a twitter.
Post Number: 1797
. (This space intentionaly left blank; I'm not too sure why.)
After I only posted about what he said, rather than what he is, Mr. Vigne said:
and then he attacks me, rather than my argument:
It would be great if you lived by your own rules.
It's strange that I actually make a living in science using those skills. But perhaps I don't make out as well as your lucrative career in sales.
Have a good night Mr. Vigne!
. (This space also intentionaly left blank; I'm not too sure why.)
Username: Nuck
Post Number: 3967
I know why.
No advertising!
Post Number: 1798
Is
this
more
readable?
Or
is
it
simply
better
when
my
posts
take
up
more
screen
space?
Post Number: 1799
What we need is a truly invisible character.
Maybe the font size can be made tiny and accomplish the same end? Unfortunately, the minimum required font size is greater than zero. (inside joke!)
Username: Nuck
Post Number: 3970
The shadow knows...
