Username: Jaguar600 Post Number: 60 Registered: Jul-05
Wednesday, August 23, 2006 - 02:46 GMT hey I'm trying to get a good setup for my gf in her cobalt thats not too cheap and not too expensive. What do you think of this setup.. 12" eclipse sw6200 and pioneer GM-7200M running at 2 ohms.
Username: Tremor1127 Post Number: 35 Registered: Aug-06
Wednesday, August 23, 2006 - 02:56 GMT you should be able to get the pair pretty cheap and it will sound good for a girls car, she will like it... if you can build boxes, you can add a nice touch by building her a cool ported box for pretty cheap...
Username: Cenus 420 ,
420
420
Post Number: 2193 Registered: Jan-05
Wednesday, August 23, 2006 - 03:01 GMT sounds nice, but pioneer amps aren't that good, i'd look for a mtx or kicker amp.
Username: Jaguar600 Post Number: 61 Registered: Jul-05
Wednesday, August 23, 2006 - 05:24 GMT any good recommendation on an amp for that? and I heard that eclipse are pretty good can you guys vouche for this statement lol
420
420
Post Number: 2198 Registered: Jan-05
Wednesday, August 23, 2006 - 15:44 GMT ya eclipse is a great companey, they make great subs and amps. what is the VC config, and RMS rating on that sub.
Username: Jaguar600 Post Number: 62 Registered: Jul-05
Wednesday, August 23, 2006 - 17:23 GMT 350 watts rms 1000 watt max I dont know the VC config? whats that
420
420
Post Number: 2203 Registered: Jan-05
Wednesday, August 23, 2006 - 17:31 GMT voice coil, like dvc2ohm dvc4ohm.
Username: Jaguar600 Post Number: 63 Registered: Jul-05
Wednesday, August 23, 2006 - 18:32 GMT dual 4 ohm, so I'd want to run the amp at 2 ohms
Username: Jaguar600 Post Number: 64 Registered: Jul-05
Wednesday, August 23, 2006 - 18:42 GMT how about an alpine mrp-m450, its 400 watts rms at 2 ohms, is that too much rms to put to that sub?
Username: Jaguar600 Post Number: 65 Registered: Jul-05
Wednesday, August 23, 2006 - 19:39 GMT if 400 watts rms is ok to put the the elcipse which can only handle 350 it states, then I am between the kicker zx400.1 and the alpine mrp-m450 unless you guys have a better option that would be less expensive...
Username: Camaro823 British Colu...
Post Number: 631 Registered: Jun-05
Wednesday, August 23, 2006 - 22:48 GMT alpine mrp-m450 is a great option, go with that. Its pretty cheap on ebay
420
420
Post Number: 2208 Registered: Jan-05
Thursday, August 24, 2006 - 00:34 GMT the kicker is the better of the 2 amps, but either amp would work. i'd get the cheapest.
