Gold Member Username: Thomas_gNM Post Number: 1507 Registered: Oct-05 | Which would u get?? I like tha lowz to hit loud and clean which would u suggest do tha job better?? Thanx guyz. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8617 Registered: Jul-05 | dd |
Gold Member Username: Thomas_gNM Post Number: 1508 Registered: Oct-05 | Kool where do i order, online?? Im pretty sure there is no local dd dealer out here where i live. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4597 Registered: Aug-05 | go to there website and look on the Dealer locator. www.ddaudio.com if there isn't any in your are you can buy them direct from DD and they will offer you with a 20% discount. |
Bronze Member Username: Sb2012Iowa US Post Number: 68 Registered: Jul-06 | the 12" is 191 plus shipping if u order from DD |
Silver Member Username: Andysd03Post Number: 379 Registered: Jan-06 | how much is a 3510? |
Bronze Member Username: Sb2012Iowa US Post Number: 73 Registered: Jul-06 | im not sure you could contact DD tomorrow...excellent service 405-239-2800 or u could email sales@ddaudio.com |
Gold Member Username: James1115Ct Post Number: 6186 Registered: Dec-04 | I would go DD over the arsenal. |
Gold Member Username: Thomas_gNM Post Number: 1512 Registered: Oct-05 | Thanx Muddy, wut if tha closest dealer is 250 miles away?? I am not gonna travel that far for sum subs so can i just order online?? they give u a discount?? Thanx for all the input guyz. Does ne1 else have these DD 2500's????? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4607 Registered: Aug-05 | 250 miles isn't considered local. lol andy had 2 10's....but he blew them. they were in a 70hz box with an Orion 2500D (on a stock charging system i believe). not sure on the Exact details. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4801 Registered: Oct-05 | DDDDDDDDDDDD |
Gold Member Username: Thomas_gNM Post Number: 1513 Registered: Oct-05 | Kool, lol^^^ ne1 know tha price for 2 2515s?? So then they would probably give me that discount?? |
Bronze Member Username: Sb2012Iowa US Post Number: 75 Registered: Jul-06 | um i think about 240 per.. yes if you order directly from DD they will give you the 20% discount |
Silver Member Username: Andysd03Post Number: 381 Registered: Jan-06 | i blew 1 DD 2510 not them both I turned the bass boost too high that prob did it the other one didnt blow i duno why just the one.the 2 10 hit 148.5db which was pretty good and they were tuned really high and they still had good SQ id only imagine how good they sound in a 35HZ box!and i had the kicker2500.1 not orion2500d i plan on getin orion2500d though |
Silver Member Username: Andysd03Post Number: 382 Registered: Jan-06 | I do have a stock alternator but i got an extra yellowtop battery for my amp + my regular car stock battery and i duno what blew my type X i was only givin it like 1800wattrms maybe it got clipped to death? lol i doubt it my system is maintaining a 14.4 volt steady and i only had the gain turn to half on the amp and the bass boost to quarter or so |
Gold Member Username: Thomas_gNM Post Number: 1516 Registered: Oct-05 | Did u like how they sounded?? Why did u have that box tuned that high?? Is it worth tha extra money to get the 2515's instead of the 2512's?? Big dif or not even if i power with the same power?? Thanx guyz. |
Gold Member Username: Thomas_gNM Post Number: 1520 Registered: Oct-05 | Which has better sq, spl, or sql?? Anybody with expirience with these subs i wanna run 1000rms to which ever 1 for now then get another and run em with a little more. |
