Username: Kbugg0041891 Post Number: 46 Registered: Aug-06
Tuesday, August 22, 2006 - 00:56 GMT man i need an amp to make these 2 12' kicker comp vr's hit hard i just need some ideas plz
Username: Blkwardog Adel,
Iowa
Usa
Post Number: 71 Registered: Mar-06
Tuesday, August 22, 2006 - 01:12 GMT hey dude i was jus comin on here to look for the same thing for a friend of mine..they r 4ohm dvc in my case so prolly an efficient class d amp thats stable to 1 ohm
Iowa
Usa
Post Number: 73 Registered: Mar-06
Tuesday, August 22, 2006 - 01:30 GMT found out that a cvr12(atleast new) is rated at 400wrms..il look at amps on my own but if neone has ne good suggestions thatd b great
Username: Cenus 420 ,
420
420
Post Number: 2189 Registered: Jan-05
Tuesday, August 22, 2006 - 02:34 GMT kx1200.1, mtx 1501d, zx1000.1, 1200d, to name a couple, whats the subs VC config, and how much do you have to spend.
Username: Juliob Santo DomingoDominican Re...
Post Number: 1992 Registered: Dec-05
Tuesday, August 22, 2006 - 10:08 GMT Dustin i think you wanna "blow" those subs... if they're dual 2 ohm get PG octane 15.0 (don't remember the other number hehe) Or kicker zx 750.1 if they're dual 4 hifonics 1206d
420
420
Post Number: 2192 Registered: Jan-05
Tuesday, August 22, 2006 - 16:53 GMT why i would think the cvr can handle 200watts over there rms rating. the 750.1 would work also but if you get the amps i listed you have room to upgrade with out having to replace the amp.
Username: Mike_16 Reedsburg,
Wisconsin
Us
Post Number: 53 Registered: Aug-06
Tuesday, August 22, 2006 - 22:11 GMT well i had 2 of them like a week ago and i had a legacy 1800 watt amp hooked up 4 a while then went to a 1000 watt mtx class d and they were much louder with the mtx the legacy had nothing on the mtx lol but ya myne were 300 rms and 600 max and they were loud but i want allot louder so im gettin 2 re sx
Post Number: 1996 Registered: Dec-05
Tuesday, August 22, 2006 - 22:30 GMT big upgrade!
Username: Kbugg0041891 Post Number: 47 Registered: Aug-06
Tuesday, August 22, 2006 - 23:56 GMT would a boss gt2500 d work wired up at 4 ohm????
Username: Dustin3 Tigard,
OR
U.S.
Post Number: 3146 Registered: Oct-05
Wednesday, August 23, 2006 - 02:02 GMT no boss pimpin
Username: Kbugg0041891 Post Number: 48 Registered: Aug-06
Wednesday, August 23, 2006 - 12:15 GMT hey bassman does your subs sound good with that amp?? how are they wired, and how many watts do u think they are pushin???
Post Number: 2007 Registered: Dec-05
Wednesday, August 23, 2006 - 18:15 GMT CVRS dual 4 ohm= hifonics 1206d hahaha lol!
