Silver Member Username: MoheeviPost Number: 115 Registered: Mar-06 | I hooked up 2 12" assassin's to a Audiobahn A8000v amp....and the subs will hit but they aren't loud at all and sound like crap anyone know what i did wrong? |
Gold Member Username: James1115Ct Post Number: 6200 Registered: Dec-04 | you prob wired them up wrong. how are they wired? |
Gold Member Username: CtmikeCt. Post Number: 1403 Registered: Feb-06 | you have the gains and everything set correctly? and what kind of box you have them in? they should sound really good, i've heard a pair and they sounded amazing for how much they cost. you do know there a sq sub right? |
Silver Member Username: MoheeviPost Number: 116 Registered: Mar-06 | yes.... this is my first time installing subs so i dont even know where i went wrong lol |
Gold Member Username: RovinTrinidad & T... Post Number: 8867 Registered: Jul-05 | a lousy box will make the best subs sound like poo ........ |
Silver Member Username: MoheeviPost Number: 117 Registered: Mar-06 | well i had 2 crap subs in this box b4 i got these subs so i put these assassins in it and it isnt as loud and doesnt sound as good as these crappy subs i had that were like 20 years old |
Bronze Member Username: JustblazeSt.Louis, MO USA Post Number: 98 Registered: Jun-06 | whats the box like? |
Silver Member Username: MoheeviPost Number: 118 Registered: Mar-06 | its one my freind made its sealed....but it was made very crappily....but if one sub plays good in it a different one should also right? |
Gold Member Username: CtmikeCt. Post Number: 1404 Registered: Feb-06 | no, different subs have different specs. could be to small/big for them. |
Silver Member Username: MoheeviPost Number: 119 Registered: Mar-06 | alright well i have the box plans for this sub...i just need someone to make it for me lol...im not good with making stuff like that |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 604 Registered: Jan-06 | just make it 1.2-1.4 cuft sealed |
Silver Member Username: Kaos13Phoenix, AZ Post Number: 156 Registered: Oct-04 | first tell us how you wired the subs no need to build another box if you just have em wired wrong....... they should be wired like the first picture here http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41 |
