New system. keeps turning off.
Username: Tropicalxkissx3
Rochester, Ny United states
ok, i may not have enough information right now to give you but here goes nothing.
i just installed a system into my car.
i have a facotry stereo still
and my remote wire is hooked up to my ignition wire so the sus/amp is turned on when i start the car.
the system sounds great, for about 10 minutes, then it shuts off. if i turn the car off and on again, it "resets" and its fine, until about 10 minutes later when it again, shuts off.
help?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3089
the problem is probably your "gain" or "level" is set to high on the amplifier
another prob. make sure your ground is very SECURE, and has a good connection, aka, you scraped off the paint, and its in contact with bear metal
Username: Dustin3
Tigard, OR U.S.
Post Number: 3090
the gain should be set to the pre-out voltage of your head unit. you first need to find out what that is
Username: Illuminator
Post Number: 4209
We need model numbers of the amps and subs you're using including what impedance (ohms) you have the subs wired for.
I'm guessing your amps are too high powered for your car in one way or another.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3095
lol. forgot the biggest one, wiring haha. its late. networking jexx, haha
Username: Coolwazabi
Nashville, TN United States
Post Number: 40
maybe ur amp has like a heat thingy where it shuts off... so it won't EXPLODE !
i checked the amp today, as soon as it shut off
and it was very hott.
could it possibly be overheating?
if so, what should i do?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1956
what ohm load do you have going to the amp?? also what model/brand and subs/speakers you're running
Username: Dustin3
Tigard, OR U.S.
Post Number: 3123
and is it just shuting off? -- or does the red protection light come on?
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 20
what does it mean if u have ure amp bridged and it goes on protect without the volume being turned up but when its not bridged it dont do that
Username: Dustin3
Tigard, OR U.S.
Post Number: 3127
ok. first of all:
whats subs? -- Ohms, dual voice coil, single voic coil...
what amp?
give us a link to both
i have one 10" kicker comp 500 sub
and a 250 watt amp.
Username: Carguy
Post Number: 5629
Michael, your problem is probably related to speaker ohms load. When bridged, you are exceeding the minimum ohm requirement. Also check the bridged mode wiring. If you short out the terminals, then it will shut down without any signal input.
Tropcial, if after 10 mins of music your amp shuts down, then you have similar problem with Michael. The speaker ohm load is too low. Also check the gain/level setting. Try turning down a bit.
Username: Mike_16
Post Number: 23
no it dont sgut off after 10 min it just shuts off whenever i try to turn the volume up so i can only kep the volume at a low otherwise whe i try to turn it up it goes on protect so i dont have it bridged anymore so how could i bridge it without it going onto protect .... i have 2 10 inch kikcer comp and a legacy 1800 watt red series but i know legacy sucks it was just a cheap amp that i could aford but now i have a job and gonna be getting 2 re sx 12s and a better amp
Username: Carguy
Post Number: 5630
If you have the money, then dump that amp before you ruinthe RE SX subs.
Double check the gain/level and VC configuration of the subs.
For 2 SVC, divide the ohm by half in parallel, in series add.
For 2 DVC, divide each sub by half, and then half again for parallel, or add in series.
thanks i'll try that.
