Good amp at 4 ohms
Username: Justdayz
do anybody know of an amp that can reach atleast 1000 watts rms or more 1500 at most at 4 ohms
Username: Illuminator
Post Number: 4248
PPI PC21400 or PPI PC2350. Ebay has them for around $300-400 pretty often. They put out 1400w RMS bridged @4 ohms and sound absolutely magnificent with excellent build quality.
Username: Feaiel
Post Number: 23
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=7 &family_id=22&item_id=95253&locale=en_US
Rated at 750rms at 4 ohms, but it averages 1252rms at 4.
http://www.rockfordfosgate.com/products/amp_power_output.asp
Post Number: 4251
Man, those are excessively expensive. Good amps too, however.
Username: Feaiel
Post Number: 24
You're right. They are more expensive. You know the saying though, "you get what you pay for." =)
Post Number: 4253
Yeah, but in this case, considering the PPI's would be used/older and the Fosgates brand new, I don't think it would apply :P
Los Angeles, CA USA
Post Number: 4814
jl 1000/1
Username: Justdayz
do you all know of any that is at a decent price?
Los Angeles, CA USA
Post Number: 4826
what is a decent price? how much are you willing to spend?
Username: Justdayz
hmmmm,about 250 -300 maybe?
Post Number: 4263
Seriously, the PPI is the best you can get if you save up around $50 more. Otherwise, bye bye quality amp. :-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1981
jexx is right and chad too... i'll tell you someting... nothing is cheap when it comes to 4 ohm RAW power... another question.. what subs r you running cuz if you're one of those guys that say that running subs at 4 ohm is the greatest is also very expensive so you know what you're dealing for....
Username: Justdayz
im running three mtx 7000 15's 12 ohms each, 500/rms 1000 pk. each, 4 ohm load together. i also have another question,i know this is a amp forum but... if the Freq Response is 20-whatever does this mean the sub will be capable of producing the low end frequency's good. or will i have to increase the cu. feet size of the box?
