New member Username: BassfiendPost Number: 9 Registered: Aug-06 | I'm still really not sure exactly what clipping is.. I've read the defitition over and over again, but I still don't get how you can "ask an amplifier to deliver more current to a speaker than the amp is capable of doing." This is the system I'm getting: 2 - 12" Sidewinders >> http://www.mdcaraudio.com/sidewinder12.html -------- 1- Massive Audio P1000.1 Mono Amplifier >> http://massiveaudio.com/lowband/prod...pro/p1000.html -------- 1- Eclipse CD-8445 Head Unit >> http://www.eclipse-web.com/cd/cd8445.html -------- 1- Dual 12" Dual Ported Box -------- Will I have to worry abot clipping? |
Silver Member Username: Rick_rossPost Number: 350 Registered: May-06 | the amp can send a clipped signal to the subs if its not being given enough power from the alternator. thats what mine does because i have 1500 rms on my stock alt and sometimes it blows my subs because they clip sometimes but i just take them back so just make sure you have warrantys on them |
Bronze Member Username: BassfiendPost Number: 11 Registered: Aug-06 | So I shouldn't have to really worry about clipping at 1000w RMS? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4545 Registered: Aug-05 | set your gains with an Oscilliscope....no clipping |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 957 Registered: Mar-04 | a simple formula, DMM, and a test tone will work just as well. |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11554 Registered: Dec-03 | two steps to avoid clipping: set the input sensitivity (gain) on the amplifiers properly, and don't turn the ehad unit up past about 3/4 of full volume. clipping is simply when there isn't enough electrical power to produce the volume (signal amplitude) you desire. The result is that instead of a sinewave signal like the amp would normally produce, you get a square wave, or at least one where the peaks of the wave are "clipped" off. The result is increased heat across the speaker coils, which can cause them damage. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1869 Registered: Dec-05 | nice system BTW |
