Is it true....................
Username: Atllefty12
Pinellas, Fla.
Post Number: 234
Is it true that the sub would be under more control at 2 ohm then 1 ohm? Local dealer says so, just wondering.
Username: Rick_ross
Post Number: 391
a little but not enough to even tell hes just trying to get you to spend more
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1881
scam... hehehe
Pinellas, Fla.
Post Number: 235
I'm thinkin of hookin up a kicker zx1500.1 to a DD 3515 or a Treo SSi. Any suggestions? If I do the SSi I'm getting the zx1000.1... Looking for mad spl w/ good sq. SSi - $425, DD - $390
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11561
damping factor will be better at 2 ohms compared to 1 ohm, THD will be lower, dynamic headroom is better, SNR is better, and so forth.
the only advantages to running at one ohm are more power, and more watts per dollar.
for SQ purposes, a higher load is superior, making the amp not work as hard and not as close to it's physical limits.
Username: Juliob
Post Number: 1936
andrew.. i'd pick the DD just me hehe
Pinellas, Fla.
Post Number: 242
I'm goin to lol... I'm just trying to make sure I get the most for my money... I want it to hurt but I wanna have some money left over to save.
