IDK?? but it keeps turning off
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 352
okay i have two twelves and whenever im knockin real hard on some notes my radio turns off then turns back on...can it be a power issue>> will a capacitor help? because i know when i get my 15"s its gonna do the same thing..and i dont like it!!
Username: Sb2012
Iowa US
Post Number: 39
probably an alternator problem...not sure a capacitor would help from what ive heard about them...
H-TOWN, TEXAS US
Post Number: 353
alternator?? so do you think its about to go out??
Username: Sb2012
Iowa US
Post Number: 40
either that..or its not putting out enough volts..and you need a more powerful one
Username: Sb2012
Iowa US
Post Number: 41
what the subs are they and what ur powering them wit?
H-TOWN, TEXAS US
Post Number: 354
they only some power references..powered by a cheap 1200 watt max amp...if its cutting off with that amp..im sure it will do it with the 15"s and the planet audio..
