Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 592 Registered: Sep-05 | I know guys that can get Subs for cheap. Around my area but i dont know anyone who can get amps for discount prices? Does ebay have any discount coupon codes still working?? FInding a 750RMS - 1000 RMS amp under 200 dollars is a MISSSION. Other then Audiobhan there isnt much there or anything at that. Would going 8Ohm stable amp be cheaper? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8590 Registered: Jul-05 | I have 1 that will do around 700-800rms @ 2ohms...let me no if ur interested |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1837 Registered: Dec-05 | any amp is 8 ohm stable... but you'll need a LOT of power to run a 8 ohm SVC sub alone... at least a 1600w rms amp at 4 ohm... so you figure it out |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 593 Registered: Sep-05 | its A DVC 4OHM sub so i can wire it to 8OHMS would that mean im running the 4OHM x 1 = 1200 WATT bridged? Chauncy what do you have ?? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 595 Registered: Sep-05 | http://cgi.ebay.ca/PHOENIX-GOLD-800w-MONO-CLASS-D-CAR-AMP-SUB-AMPLIFIER-PG_W0QQi temZ270016274556QQihZ017QQcategoryZ18797QQrdZ1QQcmdZViewItem (i would think this would be a really good amp??) http://cgi.ebay.ca/NEW-KENWOOD-KAC-9102-1700w-MONO-CAR-AMPLIFIER-BASS-AMP_W0QQit emZ270016225550QQihZ017QQcategoryZ79828QQrdZ1QQcmdZViewItem#ebayphotohosting http://cgi.ebay.ca/POWER-ACOUSTIK-A1800DB-CAR-AUDIO-MONO-CLASS-D-AMPLIFIER_W0QQi temZ180015393000QQihZ008QQcategoryZ18797QQrdZ1QQcmdZViewItem |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1848 Registered: Dec-05 | Bro you just need to wire your DVC to 2 ohms and get a 2 ohm stable amp at 800w rms |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8592 Registered: Jul-05 | Notice the fuse sizes... http://www.bazooka.com/productAutoAmplifiersRS.asp?id=199 |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 596 Registered: Sep-05 | Ya thats what im doing julilob but i need to know whats"worth" it. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1852 Registered: Dec-05 | get chauncey's one... bazooka is not so good but he knows his stuffs |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 597 Registered: Sep-05 | Phx GOld or ABhan for da budget ive come to either of these they both pushing 800RMS so what should i get? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 598 Registered: Sep-05 | http://cgi.ebay.ca/ROCKFORD-FOSGATE-PUNCH-P6002-2-CHANNEL-1800-WATT-AMP_W0QQitem Z180017241662QQihZ008QQcategoryZ39737QQrdZ1QQcmdZViewItem#ebayphotohosting Hows this? Would it go with a DVC 4OHm CVX? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8596 Registered: Jul-05 | nope...look at the specs |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 599 Registered: Sep-05 | So just get the Abhan 800RMS at 2OHM amp? IM on a budget so i cant do much streching of the budget. |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 600 Registered: Sep-05 | 200USD MAX... What are some underground amps that arent talked much about but are really good? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 603 Registered: Sep-05 | http://cgi.ebay.com/NEW-POWER-ACOUSTIK-SL2-2000-2Ch-Car-Audio-Amplifier-Amp_W0QQ itemZ220015833231QQihZ012QQcategoryZ18796QQrdZ1QQcmdZViewItem I came across thiss?? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 604 Registered: Sep-05 | http://cgi.ebay.com/NEW-HIFONICS-ZEUS-ZXI-1000w-2-CHANNEL-CAR-AMPLIFIER-AMP_W0QQ itemZ270015971963QQihZ017QQcategoryZ18796QQrdZ1QQcmdZViewItem ? |
