Kicker CVR12 sub question
Username: That_wasnt_nice
Hey guys. I recently bought One Kicker CVR12 sub, but it is has a 2-ohm dual voice coil.
The wiring part is confusing me since it's 2-ohm. The reason is, I can't wire just one sub in a 2-ohm setup, right? I would need to wire it as 4-ohm... but would wiring my sub @ 4-ohm work without causing any problems??
also i was planning to get the audiobahn a8000t amp and run it at 4-ohm, but im not sure if its possible or not.
any help would be appreciated! thanks.
Username: Rick_ross
Post Number: 328
you can either wire it at 1 ohm or 4 ohm it would be better to get a better amp that is 1 ohm stable and puts out around 500 rms instead of getting the audiobahn
Username: Killer44
Ontario Canada
Post Number: 630
no that sub can be ran @ 1ohm in parralel, or 4ohms in series, it should show diagrams in ur manual, or use these http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =1&impedance=DVC2x2
u could use the a8000t and run it @ 4ohms giving the sub 400rms...if u need any more info jsut ask...
Username: Tjmutlow
Post Number: 2712
if you run it at 4 ohm then get the 8002 model, 2 channel bridged, or an amp that is 1 ohm stable...
