Bronze Member Username: OglejustPost Number: 19 Registered: Aug-06 | ok i made a 2in diameter 7in long port out of pvc pipe. they say that will tune it to 40 hz. well i can move the pipe in and out... to change how much is in the box... and it made no difference. is it because its still 7 in of pipe whether 7in is in the pipe or 3 is in the pipe? to hear a difference do i need to cut the pipe? i just want my sub to be LOUD! i want pure spl. if my 12in sub is in a 2.4^ft box how big and deep should the port be to make it loudest? thanks |
Gold Member Username: RovinTrinidad & T... Post Number: 8823 Registered: Jul-05 | y did u pick 2 use a 2" port & also tune so high ?...... |
Gold Member Username: James1115Ct Post Number: 6115 Registered: Dec-04 | yes its the length and width of the port that gives it the tune. The difference between it being in the box and out would only be displacement which wont amount to enough to change much (not audibly anyway). If you make it shorter yes it will make your tune higher, but unless you are running a subsonic filter I don't reccomend it. The higher the tune the less musical it is due to the fact that a sub will lose control on any notes below tuning. That means that you will easily cause your sub to over excure and blow if not fixed. |
Bronze Member Username: OglejustPost Number: 21 Registered: Aug-06 | well the only pvc pipe i had was 2 in... should i get 3 in? if so how long should it be to tune to 45hz? how long for 35hz? |
Bronze Member Username: OglejustPost Number: 22 Registered: Aug-06 | would a 45hz tuning be louder (spl) than a 35? |
Silver Member Username: J_baby15Kentucky Post Number: 489 Registered: Feb-06 | for straight spl, try a lil bigger box, wit 2 3" or 2 4" pipes and tune to like 40hz. but if i was u i would go wit like 2 3" and tune to like 35. what kinda sub makes a lot of diff. |
Bronze Member Username: OglejustPost Number: 24 Registered: Aug-06 | ok thanks. 1 more question... how long should the 2 3in pipes be to make it 35hz? |
Gold Member Username: RovinTrinidad & T... Post Number: 8824 Registered: Jul-05 | justin : which sub do u have ?..... |
Bronze Member Username: OglejustPost Number: 25 Registered: Aug-06 | well, dont laugh but right now a pioneer 12in 450watt. |
Bronze Member Username: OglejustPost Number: 26 Registered: Aug-06 | thats just until i get some money saved for a new one. |
Gold Member Username: RovinTrinidad & T... Post Number: 8825 Registered: Jul-05 | http://www.carstereo.com/help/Articles.cfm?id=31 http://www.the12volt.com/caraudio/boxcalcs.asp its cool - i own pioneer's 306 subs b4 which exact model no u have ?...... |
Bronze Member Username: OglejustPost Number: 27 Registered: Aug-06 | TSW33C i have 2 but a buddy of mine is usin 1 |
Silver Member Username: J_baby15Kentucky Post Number: 490 Registered: Feb-06 | Rovin...dont you have a 2500d? adn 2 type rs? |
Gold Member Username: RovinTrinidad & T... Post Number: 8827 Registered: Jul-05 | ya Jordon - but due 2 me NOT upgrading my electrical as yet my new orion amp is just sitting there but temp powering my Rs with my bro's power acoustik amp man that TSW33C is an old model sub -lol ..... |
Silver Member Username: J_baby15Kentucky Post Number: 494 Registered: Feb-06 | ight. I was j/w b/c i jus got a 2500d and i hav the chance to get 2 type Rs and was wonderin how good of a combo that is. How many dbs r u hittin wit that PA amp? Well i dont kno much about the pioneer sub, but i would say 1 4" then should b good, or 2 3". |
Bronze Member Username: OglejustPost Number: 28 Registered: Aug-06 | yeah yeah laugh it up!!!! lol ha ha ha yeah its real funny. have u ever heard a phoenix gold 12in elite titanium? |
Gold Member Username: RovinTrinidad & T... Post Number: 8829 Registered: Jul-05 | never got it metered but in a recent new slot port box it had objects on a wall falling down & my windscreen moves alot i agree with 1 4" or 2 3"...... |
Bronze Member Username: OglejustPost Number: 29 Registered: Aug-06 | what is the best treo they make? the csx? |
Silver Member Username: J_baby15Kentucky Post Number: 498 Registered: Feb-06 | CSX is for short burps only. SSX would b the best for daily driving SPL. SSI are good SQL-more toward SQ i think. Mine sounded nice. TSX are SQL too i think. but more toward spl from wat i hear. |
Bronze Member Username: OglejustPost Number: 31 Registered: Aug-06 | i want something that will hit like high 140s or 150s. u suggest anything? |
Gold Member Username: RovinTrinidad & T... Post Number: 8830 Registered: Jul-05 | DD & $$$$$$$ ........ |
Bronze Member Username: OglejustPost Number: 32 Registered: Aug-06 | like what model and how much $$$$$$$$$ |
