Hey guys and/or gals. I need a little help with my tv. It's a sharp aquos lc-37db5u and sometimes when I turn it on, it kind of pixelates things. It also flickers with horizontal lines. I'm not sure of the best way to describe it but it's like interference or something. Anyways, it's only a few months old and other than this problem it works fine. I should also mention that this problem doesnt occur all the time but it does occur often and it will sometimes go away on its own or after I turn it off and turn it back on maybe 5 minutes later. Anybody know what is causing this problem and how I can fix it? Thanks in advance.
Could it be the electric system of your home. Try a grey 3 to 2 plug connection this may help with electric feed back. Had a sub that buzzed applied one of these adaptors and it went away.
