Where is Blacklist??
Username: Emperorrotm
Post Number: 50
When the Viewsat fix came out, BL's site didn't even update anything. They didn't even mension that a fix was out. I guess BL help VS in getting this fix. Maybe I'm wrong. I dunno. Just a guess.
Username: The_wank_artist
Post Number: 1536
After the last ECM the Pansat bin came out about 48 hours after the Viewsat fix, so give him a bit more time.
If things go in the same order, we're looking at Pansat next followed the next day by Cools@.
But if you're a betting man, you'd be better to box the three of them and let it all ride.
Username: Evadelparaiso
Puerto Rico
Post Number: 1626
Welcome again, Wank artist.
Post Number: 1538
Which Eva is this I'm talking to???
Username: Morispastora
Thunder bay, Ontario Canada
Post Number: 24
Maybe to the Viewsat seller.
Puerto Rico
Post Number: 1630
Im the real Eva, Tyler. :-), i mean, let me see. Yes I am.
Puerto Rico
Post Number: 1631
lol I do not sell viewsat or another equipment for satellite. O_O
Username: Zagros
Post Number: 77
Right here:
Username: Ffpalms
Palmdale, Florida USA
I need help. I cant find a thread for helping me fix a 3500sd. I loaded a 353 updated bin and it wont turn back on. I'm getting a 6-70 on the display. Can anybody guide me. jtag? Thanks
Username: Etorres4u
Post Number: 113
The Pansat site is "down for maintenance" If experience is any guide that might actually be good news. They always take the site down for maintenance when posting new bins. Lets wait and see.
Post Number: 1542
Wiggles,
That sounds like a B-70 error message.
I think all you need to do is load the factory bin and you should be back up and running.
Get the file from any good fta site.
Username: John_c
well don't get your hopes up too much for tonight. they also take down the site when it gets overloaded which is expected after the news of the fix came out
Username: Rufa33
Post Number: 151
Wiggles Mcgee, as Tyler said, you need to get on a factory bin and load it, sometimes takes more than once, perhaps several loads to make your pansat back to life. Be patient and good luck.
Username: Ffpalms
Post Number: 9
Thanks for the info. I used the memory card to load the bin. Time to hook up the computer and use the loader thanks. i have a factory pansat bin.
Username: Kriskros
Post Number: 19
WM describe the process to upload bins with SD memory card please. My laptop with cable port is dead, new laptops dont have that kind of port. Thanks.
Username: Birdwatcher
Post Number: 196
Black list is working for viewsat....
Username: Hawaiian_time
Hawaii
Post Number: 407
kris, here's a c&p from satcruiser:
how to Load and Save Files to the Pansat 3500S
3500 - THE SD/MMC WAY:
Insert virgin SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Note: Receiver will automatically create 3 directories on the card:
CH Data Backup
Code Backup
MP3
(For Virgin cards only -Take the card out at this point and load your unzipped bin or channel list file to the card in the appropriate directory. Now put the card back in and re-access via menu as stated above.)
Select bin file in appropriate directory, main directory, [ch data backup] or [code backup]
Press [OK]
Select [data restore]
Press [OK] to load, receiver will automatically load, confirm, then reboot.
TO SAVE DATA
Insert SD/MMC card into receiver.
Press [menu]
Select [SD Memory]
Select an appropriate directory, main directory, [ch data backup] or [code backup] by using [up or down arrows] and [OK]
Press RED button in left bottom corner of remote.
Name your file on the alphanumeric screen file by scrolling via [arrows] to next character and then pressing [OK] for each character or [del] to correct a character. To save selected name, press [OK] on the alphanumeric screen.
Bin File will then write automatically to the correct directory.
Size of files:
CH = 352 kb
Code = 768 kb
Use GREEN button (beside the RED button) to delete selected and unwanted
files.
Username: Lebrimal
Post Number: 48
blacklist is kissing his viewsat
Post Number: 213
hes ramming it in his azz
Username: Mortimer_snurd
Post Number: 10
Someone jokingly said earlier that Pansat went out of business.Well,think about it,its possible.Perhaps they just decided that investing more money at this point would be unwise??? And like the man said,maybe BL went to work for VS?Mind you.they would be wise to announce that so the hard liner Pansat guys/broads would by viewsats? Then on the otherhand,the bin could be out in the next hour.
I hate to admit this,but I should of bought a Viewsat.
Post Number: 218
nah, either way, we're all in the same boat. Im just messing around, Pansuck will work again soon. there is some person smarter than Charlie
Username: Abdou91
514
Post Number: 60
NL said for peoplewho are waiting for new binUpload
Username: Ronmcc02
Is their anything for viewsat 2000 yet, I just bought this thing right before the hit and i don't know how to get up and running. The guy I bought it from set up it up at first. I would appreciate if someone could me get started. I would like to at least get a local channel.
Username: Pedrin
Alguien me puede decir como le quito el autorrol a mi fortecstar life time ultra gracias
Post Number: 12
Ronnie Mccewen go to dsstester.comm only use one c after com.Go to Viewsat receiver section and download the latest autoroll bin.You also need the loader 2 and a sat info guide.Read the how to on how to set up your vs.You will have to read.
Username: Lebrimal
Post Number: 49
I went to the doctor and he game pain killers name viewsatin.
Username: Alex_cheung
Post Number: 46
PanSat is history now... BL is busy fixing his website... not the Bin... and begging VS to share the file...
