MTX 9500 15inch or Kicker l7 15 inch WhIcH Is LoUdEr
Username: Bump05
Hesperia, CA USA
Post Number: 19
which one would be louder spl wise
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1843
kicker
Username: Bump05
Hesperia, CA USA
Post Number: 20
ok how about 1 15 kicker l7 or mtx 15inch 9500 or 2 alpine type r 15 inch
Username: Bump05
Hesperia, CA USA
Post Number: 21
2- Alpine type r 15"
1- Kicker l7 15"
1- MTX 9500 15"
Which one will have more spl thanks?...
Username: Justblaze
St.Louis, MO USA
Post Number: 68
ok 2 dwscent 15s will always be louder then 1 15. i dont think the mtxs are that much better that it wold produce twice the spl as a type-R. a type-R will sound a lot better doing it too.
Username: Justblaze
St.Louis, MO USA
Post Number: 69
** 2 descent 15s
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1746
nope the 9500 will be louder why??? it has greater xmax and grater vd, plus in the contes on cxi i think the 9500 it came in 4th place in spl and the 9500 will be loduer than the kicker l7, yes the l7 have good output and get loud
Username: Justblaze
St.Louis, MO USA
Post Number: 72
so your telling me a 9500 will overpower TWO type Rs? wouldnt that mean the 9500s xmax would have to be twice as much or am i off base here?
Username: Skies
Courtenay, British Colu... Canada
Post Number: 238
2 type rs will be 3dB louder than 1 type r, given the same power for each. it all depends on box.... I've seen 1 15" type r hit 155.x ...havent heard much for numbers on the 9500... but i saw some at a car show once, and they were insanely loud, and hardly moving....
I would go with 1 9500. Better SQ than both others mentioned, and just as loud, if not louder
Chicago, Ill Us
Post Number: 1747
no im compraing the mtx 9500 with the kicker l7
Username: Justblaze
St.Louis, MO USA
Post Number: 75
oh i thought you were responding to my message my bad
