Bronze Member Username: Nickyp0219Post Number: 83 Registered: Jun-06 | hey guys i was wondering if i should wire my L7 in series or parallel to memphis pr1000.1?? i heard that in series its more efficient and wont heat up the amp, but you have to turn the gain on the amp up a lil bit more. what do you guys think? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1826 Registered: Dec-05 | hm... someone is lying, you don't need to turn the gain up... you just need to match it to your HUs preout voltage www.the12volt.com and hit the link woofer wiring... |
Bronze Member Username: Dwight11Post Number: 13 Registered: Aug-06 | i think u should probably invest in something other than an L7 (L is for lamest peice of crap ever invented) |
Gold Member Username: IlluminatorUSA Post Number: 4067 Registered: Apr-05 | Dwight: You clearly have no idea what you are talking about, then. Stop spamming, dude. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1847 Registered: Dec-05 | great SPL sub, that's it |
