New member Username: Ranny555Nyc, Ny Usa Post Number: 3 Registered: Jun-05 | Hi I conected USB adapter wireless and set up the network under my network. i get excellent signal icon but i cant get internet access i tried the repair conection ,message shows repaired but i still get no internet everything looks O.K ,but i cant figure what is wrong. Thanks for the help |
Gold Member Username: IlluminatorUSA Post Number: 4045 Registered: Apr-05 | Have you tried resetting the wireless router? Make sure the browser you're using is enabled to connect to the internet directly(hopefully it's IE, because that's what I'm going to give you instructions for). Go to the 'connections' in IE and delete any connections in the box, then go to "LAN settings" and uncheck any boxes. |
New member Username: Ranny555Nyc, Ny Usa Post Number: 4 Registered: Jun-05 | tried that ,doesnt work . i am getting the wireless sign as excellent but still can not view websites ... any other way i should go ? i will reinstall the USB adapter and try a gain but i allready tried it twice. I dont have Ethernet exit so i can not try do it direct please help |
Gold Member Username: IlluminatorUSA Post Number: 4055 Registered: Apr-05 | Wifi is a type of direct connection. Best way to troubleshoot is this: install firefox-another web browser- (http://www.mozilla.com/firefox/) and see if that lets you browse the web. If it doesn't, then you have a problem with your adaptor, if it does then IE is to blame. |
