Weird
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 454
ok i was drivin down the road the other day and i sent my L7 off to kicker to get a other one and i had my amp in the back and crossover and capcitor and everything was hooked up but see i took my 100 amp fuse outta my fuse holder and i noticed the other day that i was still gettin power and my amp went into protection mode and i dont see how it got power without the fuse in it? i just cut my hot wire cuz i couldnt undo it but if i move the hot wire up or around somewhere it gets power but if i move it again it dont whats the damn dell with it is it a short or something?
Post Number: 455
bump
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1801
remove the wires from the battery...
Post Number: 462
why? whats the problem
Post Number: 467
bump
Username: Illuminator
Post Number: 4023
Can you take any pics of your install?
Username: Ctmike
Ct.
Post Number: 1318
you doing all your install yourself?
Username: Safe_cracker
Chicago, IL US
Post Number: 1329
Maybe the amp was drawing power from your remote wire and becasue there isn't enough current, the amp went into protection mode? Cheap amp? Polo.
