New member Username: NkryptykPost Number: 1 Registered: Aug-06 | I Got A Pioneer Radio Forgot What Model Buts Its 50x4 watts and i got a 500 4/3 channel sony xplod amp pushing two sony xplod 10" 1100 Subwooffers And Something Isnt Right Its Not With The Wiring I Know Thats On Point Its The Sound Would I Need Anything Else To Make It Sound Better |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3004 Registered: Oct-05 | well, i know why 1. sony sucks, --- and you have their amp and subs to make it sound better, you need to make sure it is wired correctly, and that the VC configuration on the subs, presents a load that the amp cant handle. or you have it wired to a wrong load = less watts. can you give a link to what subs you have -- EXACT, VC config, ohms etc. and then another link to your amp... |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3005 Registered: Oct-05 | having a correctly built box will make all the dif also. |
New member Username: NkryptykPost Number: 2 Registered: Aug-06 | hmmm let me go see |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3008 Registered: Oct-05 | ok |
New member Username: NkryptykPost Number: 3 Registered: Aug-06 | cant find no pics or info ? |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3013 Registered: Oct-05 | hmm. you have the box or anything? |
New member Username: NkryptykPost Number: 4 Registered: Aug-06 | yea i got it in a box |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3014 Registered: Oct-05 | http://cgi.ebay.com/ebaymotors/Sony-Xplod-600w-4-3-Channel-Amp_W0QQcmdZViewItemQ QcategoryZ38638QQihZ016QQitemZ260020049795QQrdZ1QQsspagenameZWDVW this the amp?? sub? -- http://www.xplodsony.com/xplod/subwoofers/XS-L103P5B look on that site or somthin |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3015 Registered: Oct-05 | check the box or somthin to see what model they are |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1823 Registered: Dec-05 | throw it away or sell it |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 317 Registered: Jan-06 | Best thing to do to make it sound better...get rid of the Sony stuff and buy something better...even if you have to wait a while and save up the money...sony....yuck! |
