Silver Member Username: Dub_cPost Number: 133 Registered: Mar-06 | Not the best overall 12" sub, I am NOW looking for the best 12" sub, that is LOUD, and has GOOD CLEAN BASS, 350-400WRMS, SVC 4 ohm or DVC 2 ohm, all of that and it will go in a .8 SEALED BOX! Thanks |
Gold Member Username: CtmikeCt. Post Number: 1264 Registered: Feb-06 | http://www.cardomain.com/item/IDSID12V3D2 |
Silver Member Username: Dub_cPost Number: 135 Registered: Mar-06 | These again, are there any more out there? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1733 Registered: Dec-05 | JL, AA assassin, CVR... infinity's bla bla bla |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1734 Registered: Dec-05 | CT mike is right, that's very good |
Silver Member Username: Dub_cPost Number: 138 Registered: Mar-06 | Which JL, which Infinity, CVR's need 1 cu. Yes I know all about those ID's I was just wanted other brands. |
Gold Member Username: IlluminatorUSA Post Number: 3895 Registered: Apr-05 | In a .8" cu. feet sealed box? Good luck...closest thing I can think of are the 12" JLw3v3's. The ID's are the ones if you want the sub to match to what you want, otherwise you'll have to do some more research and be more flexible... |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 2928 Registered: Oct-05 | yea. .8 is very small for a 12". 10" would be closer to .8 i guess, but still a lil small. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4297 Registered: Aug-05 | jesus. just go with the ID's. if i knew of something better, i would have recommended it already. lol |
Silver Member Username: Dub_cPost Number: 140 Registered: Mar-06 | Aight, Imma buy 1 ID for now, and if your wrong Muddy Imma hunt you down! ha, naw I trust you bro! |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4317 Registered: Aug-05 | it just seems to me that there isn't a better sub for your power requirements and box space. so sue me if ya don't like em....but they WILL sound good. |
Silver Member Username: ShowridesHartford, CT USA Post Number: 162 Registered: Feb-06 | IA 187's I am working with now, and tomorrow I am getting in some Mass Destruction Sidewinders. The 187's sound great with that amount of power, and get very loud as well. Overall a great sub if you only have 300-400rms to work with. The Sidewinders are supposed to have even more output than the 187's and SQ is supposed to be very similiar. But I haven't tested them out yet, so I can't tell you exactly how they will be. After tomorrow though I should have an okay idea of what to expect form them. |
Silver Member Username: Dub_cPost Number: 142 Registered: Mar-06 | Aiight, hey so Muddy, do those ID's get crazy loud? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4361 Registered: Aug-05 | ummmm no. but they take 300-400 wRMS and they have roughly 17mm of Xmax....and i know they sound good. lol what more do you want!!!!?!?!?!??!?!?!?! |
Silver Member Username: Dub_cPost Number: 143 Registered: Mar-06 | I'm one of them people that like to be heard from a mile away, well not a mile, maybe half a mile! HA! Naw but yea, I like'em loud. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1745 Registered: Dec-05 | well... hehe at least they will sound good hehe |
Silver Member Username: ShowridesHartford, CT USA Post Number: 187 Registered: Feb-06 | The id's are more SQ subs. They don't get crazy loud, but they will sound good. |
Silver Member Username: Dub_cPost Number: 144 Registered: Mar-06 | Well I am asking for a lot for little space. |
Silver Member Username: Dub_cPost Number: 145 Registered: Mar-06 | Hey what about these http://www.cardomain.com/item/KIC06CVX102 These should be loud and sound clean, I know they are only 10's. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4419 Registered: Aug-05 | Sealed Box Dims: .8 - 3 cu.ft. if they will work with your space...get them. |
