is there a single 18" sub that would reach 150 DBs with a good install in a 4 door tahoe?? I was thinkin the audioque HD3 but any other suggestions thanks alot
make me a good offer and maybe i can sell u my my sx, 145.3 in an explorer with 1500 rms on the termal lab, with a precicion pwoer dcx1500.1 the woofer have like 5-7moths of waranty i have the receip and everything,
if u dont want re audio,
digital design (willbe more than your budgetz) ficaraudiio amercan bass some treo ssx but they need alot of watts atomic apx
not these speakers will giv you 150, u have to make a good box and give it good power 150 its not easy and even the best subwoofer ull need to have a good set up, i seen 4 15 cant even get to the 140's because of their poor install
yeah you can't go wrong with the re sx 18 man. the sq is decent and the output is unbelievable. i gotta find a place to get mine metered. i am only giving it 1000wmrs and it feels like my back windshield is going to pop out. i can't turn it up too loud cause i am afraid something in my car will break. lol.
hey chad. i keep seing threads about the re sx. im gunna get the zx1000 whcih will do like 1100rms. do u think i should have got the 15 sx, instead of the 15 ssi?
the ssi sounds better than the re sx. alot better. don't get me wrong the sx isn't that bad sounding. its just the ssi has awesome sq. but the sx gets louder than the ssi by alot.
my single re sx 18 powered with 1000wrms gets just as loud as when i had 2 ssi 12s with 2000wrms. it also hits deeper.
a sub i do want to try out real bad is the ssi 18 though. i think it will sound so clean and deep. i've only heard the 12 inch ssi so i don't really know what the 18 inch will sound like. big difference between 18 inch and 12 inch subs.
the jbl is cheaper so go with the jbl. they are both good amps. i prefer kickers but thats just me. i am a fan of kicker amps. they underrate their amps so much.
