Silver Member Username: Crayola0Wisconsin Post Number: 540 Registered: Jun-06 | Is this actual 0 Gauge Wire? http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=PK3000P or http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15609 |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4682 Registered: Oct-05 | i can't tell looking at the picture but it says it is so it is. i don't think people would lie about things like that. |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 310 Registered: Jan-06 | Don't know about the first link, but onlinecarstereo is a good place to buy from. and since it does say that it has 0 gauge wire, I would say yes it is. |
Silver Member Username: ShowridesHartford, CT USA Post Number: 210 Registered: Feb-06 | They will both do the trick. Not all 0 gauge wire is the same, some has more strands of wire than others. But if you haven't worked with it before, it won't make a big difference. It takes some time to learn how to cut it correctly, and strip it. Also, fitting it into terminals is never easy. So that 0 gauge will be just fine for what you are looking for. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4683 Registered: Oct-05 | have you guys tried stripping the 0 gauge with your teeth? not an easy trick. |
Silver Member Username: Crayola0Wisconsin Post Number: 541 Registered: Jun-06 | i was also wondering if this was a good battery? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4576&C FID=1679162&CFTOKEN=deceffea6accc524-FDE1BA9E-1422-7C6E-50696FFDF2E8D482 |
Silver Member Username: ShowridesHartford, CT USA Post Number: 217 Registered: Feb-06 | Chad Lee...No I use scissors to do it haha. |
Silver Member Username: Crayola0Wisconsin Post Number: 545 Registered: Jun-06 | ? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4684 Registered: Oct-05 | its cause i asked if he stripped a 0 gauge cable with his teeth before. j@yme$......have you tried looking around your local stereo place for the 0 gauge cables? although it seems like it cheaper online, with the shipping it itsn't. if you know a friendly stereo place then you can get it for cheap. i pay $25 for a roll of 0 gauge which is around 25 feet. the brand is hugfen but it does the trick. |
Silver Member Username: Crayola0Wisconsin Post Number: 546 Registered: Jun-06 | the only shops around me are in baraboo and madison i beleive. im gunna go there some time and look at component speakers. so ill check it out. |
Gold Member Username: Alias747MN Post Number: 1181 Registered: Apr-05 | Jayme go here: www.knukonceptz.com Awesome cable for a good price. All of there cables are bigger than they are actually sized. Like their 4 gauge is more like 3 gauge. Good stuff. |
Silver Member Username: ShowridesHartford, CT USA Post Number: 231 Registered: Feb-06 | I just bought battery terminals and 0 gauge wire terminals fro knukonceptz. I have to say it did end up costing a little more than I wanted, but I couldn't argue at all with the products. Very nice stuff, and very easy to order from. |
Gold Member Username: IlluminatorUSA Post Number: 3932 Registered: Apr-05 | Do you really use scissors to cut/strip 0 gauge? I remember when I bought some by the foot, the guy used scissors...I have heavy duty wire cutters that work much better. :P |
Silver Member Username: ShowridesHartford, CT USA Post Number: 259 Registered: Feb-06 | I use the heavy duty wire cutters to cut 0 gauge wire. I use scissors to cut the jacket off around it. If you cut at an angle it works perfectly. |
