Need help with wiring two amps!
Username: Lpg
any body have a diagram on how to hook up two amps together! heres my amps, jl audio 500/1 and alpine mrp-450. heres the amp kit i have JL Audio XA-PCS4-2. thanks in advance. I've hooked amps up before but only 1 amp, not 2.
it has 30 foot postive 4g and 10 foot negative 4g. then it has distrubution block and 16 foot remote. also has 8g postive and 8g negative. so im just wondering how to split the remote.
Username: Lpg
bump... damnit i need a diagram on how to hook two amps together... i'm just dying to hook my system up but have never hooked two amps together and dont wanna fuc7k things up.
thanks
Username: Illuminator
Post Number: 3959
Use a distro block to split the power wire in two, one for each amp. Then just wire the two remotes to the one coming from the head unit. That's the only deviations from hooking up a single amp you'll encounter. Not too difficult.
Some people like to use a distro block on the ground wiring as well(so they only have one grounding point), but I think it's a waste of money.
