Showrides
Username: Crayola0
Wisconsin
Post Number: 538
Do u know what size wire the the Massive P3000.1 accepts?
Username: Showrides
Hartford, CT USA
Post Number: 208
It will accept 0 gauge power wire. They suggest you use 0 gauge wire with a 200amp fuse.
Username: Crayola0
Wisconsin
Post Number: 539
alright thanx.
Username: Showrides
Hartford, CT USA
Post Number: 211
Just make sure to go pick it up from Ben. He seems to have the lowest prices on the p3000.1's by far. And you get massive's full warranty since he is an authorized dealer.
Username: Crayola0
Wisconsin
Post Number: 542
alright i was plannin on gettin it from low-hz anyway.
Username: Crayola0
Wisconsin
Post Number: 543
whats size alternator do u think im gunna need?
Username: Showrides
Hartford, CT USA
Post Number: 216
I would get atleast a 250amp one if you could. That would be a great start to help run that amp.
Username: Crayola0
Wisconsin
Post Number: 544
aight thanks
Username: Crayola0
Wisconsin
Post Number: 548
can that amp accept 1/0 gauge. cause thats what they have a knukonceptz.
Username: Showrides
Hartford, CT USA
Post Number: 232
Yeah of course. And I just ordered from that site. They are a good place to get stuff from, but cost a little more than other places. But you can't argue with their products.
Username: Crayola0
Wisconsin
Post Number: 549
alright i think im gunna get my wire from there. cause with the amp kit u can pick ur fuse and so ill pick the 200 amp one. And it come with more ground wire to upgrade from the battery to the chassis. what does that do?
Username: Crayola0
Wisconsin
Post Number: 550
actually i think im gunna go with the one from onlinecarstereo cause it is 70 bucks and come with speaker wire
Username: Showrides
Hartford, CT USA
Post Number: 238
hehe...You should be very happy with either. Both will get the job done well.
