Pause between bass notes
Username: Nickyp0219
Post Number: 54
hey guys i just got my sub and amp hooked up today and when i turn the car on and/or shut the radio off and back on, the song starts playing but the bass doesnt start kickin in for a couple seconds??/ whyyyy thanks
Username: Basshead86
Google is your Friend, FL
Post Number: 4312
the amp has to power on.
my system does the same thing.
my mids and highs amp starts playing like 2 seconds before my bass amp turns on.
Post Number: 55
is that normal?? i just didnt know what was goin on. its a memphis prd 1000.1 to a kicker L7
Username: Safe_cracker
Chicago, IL US
Post Number: 1297
There is a delay in the remote turn on. if there wasn't there would be a thump/pop when it powered up. Polo..
Post Number: 58
hey now nothing is happening. the amp isnt even turning on. just got it installed today. ?? music plays, just w/ no bass
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 430
what kinda box u get for the L7?
Username: Riskyb
Post Number: 73
Good amps have a silent turn on and take a few seconds to power up so you don't pop your sub/speakers. But if you say it wont turn on at all now... thats no good!
Post Number: 61
tyler i got the custom sealed one i mentioned earlier. takes up almost the whole trunk but that thing poundddss. Dam_n thing wont work right now lol. brining to custom car sound first thing in the morning. let ya know how it goes. peace
Username: Feaiel
Post Number: 21
Did you check the fuses? If your amp isn't getting power then it would be the first thing I checked.
BoL
Username: Firestomper25
Kenmore, Ny United states
Post Number: 16
i dont mean to interupt but i just need an answer on a quik ? do you know what i need to buy to connectmy amp to my head unit to control it
Post Number: 431
heck yea i told ya that amp would push that sub hard
i should be gettin my new L7 back tommrow or friday and cant wait
Post Number: 62
yea i went there and they said the gain was f'ed up cause they tried to give it more cause the amp is 1000 watts and the sub is 1500??? its a 1000watt rms sub but they said cause its a 2 ohm ? i was confused. then some guy came out and said they had it hooked in parallel, when it should be hooked in series. is this correct for my setup or should it be in parallel. tyler whats urs set at? thanks bro
Post Number: 63
i thought at parallel itd be putting 1000 watts rms @ 1 ohm??
Post Number: 432
i have a 2 ohm and i just hooked the wires behind the sub its mono set so i can just push the amp to a full 1100 watts
man that guy dunno what hes talkin about "1500" that sub is 1000 to 2000 it reccomends throw 1000 rms into that sub weather its 2 ohm or 4 ohm
Chicago, IL US
Post Number: 1307
Is it a dual 2 ohm voice coil sub?
Post Number: 64
yea its a dual 2ohm voice coil to a memphis pr 1000.1 mono block
Post Number: 65
the guy mentioned that my amp gain was too much even tho he turned it down cause the bass shut off again. also he said it could be that my amp is mounted on the back of my seat and isnt cooling properly so i should put the seat down. lemme knowww
Post Number: 66
tyler did you wire your L7 down to 1ohm load?? also i have a stock hu if that makes a diff.
Post Number: 67
guy tried jump starting my sub but it would bump when he put the wires to the amp but when he let off, it did nothing. he said my wiring could be wrong or its my equipment???
Post Number: 68
Post Number: 438
yea i got factory alternator and battery im gonna upgrade soon
but yea i got my sub wired for 1 ohm and everything what gauge wire are you using? and yes keep the gain to about 75% up all the way or a lil more but adjust the amp right dont be a dumbazz like me and keep the amp turned all the way up cuz u will melt a voice coil with that amp in 30 min lol
Post Number: 69
im using 4 gauge wiring.
Post Number: 439
is it loud enough for you?
i should be gettin my new L7 in today and i know there loud in escalades but i dunno about eclipse what kinda box do you have? u go ported?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1755
match your gain to your HU preout voltage
Username: Showrides
Hartford, CT USA
Post Number: 250
The correct way to set your gains.
http://mobile.jlaudio.com/support_pages.php?page_id=143
