my friend just installed his indash dvd player that he bought from me. i replaced mine with a pio premier 960. awesome HU btw. anyways he wants to watch dvd while he is driving and he don't know how to connect it. everything works but watching dvd while driving don't. i know you need to istall some kinda switch but how do you do it. can someone help me out here.
Check the manual carefully. On the DVD unit, there's a remote trigger wire. It's probably connected to the parking brakes. Take that wire and attach it to the ground. After that, it's play will not be affected by the movement. It's just a safety feature built in the players. In some places, it's illegal to modify that.
k thanks. on the manual it just says connect the light green wire to the parking brake. when that hu was in my car the installer made a little switch so i would have to flick it on then off.
